UcD400 has been reviewed in the danish/swedish "High-Fidelty" (No. 4 /2006). Good reviews was the verdict. I will translate the article later on if there is any interest for this.
The raw file can be located here:
http://sjostromaudio.com/ucd400_review.pdf 8 MB big but I will make it smaller + english text.
just wondering why they've put the 2 modules so close to eachother with the first channel output coil radiating on the 2nd channel modulator(UCD)? No symmetry. Beats me
That must have an effect on the soundstage.
Anxious to read the story.
Gapped coils placed like these will produce a stray magnetic field with flux lines perpendicular to the horizontal plane, thus they will only cause induction in other circuits laid across the horizontal plane. The daughter board is intentionally placed in a vertical plane to avoid induction from the coil or from the own tracks of the main PCB, that also produce stray flux lines perpendicular to the horizontal plane (not accounting for ground plane "shorted-turn" effects).
In practice it means that induction will be the minimum possible. Indeed, these "geometry" tricks are quite common in SMPS (and not so common in class D due to the rather clumsy layout abilities of most designers).
Eva, my first UCD amp. I've made in the same way, the modules where a bit nearer to eachother though, and found out 1 channel was influenced by the others modulation. On a scope I could see the modulation change in the other amp.
It is not a very sophisticated way of placing switching devices like this in an audio app. My view though.
How did you measure that? Was there asymmetric cross-talk in the audio band?
Note that you will get induction on the own amplifier wiring and oscilloscope leads if you place them near the coils.
I agree that it's not a great idea to place a modulator just near a coil, but if they must be placed together due to space constraints, that's the best way to do it.
Peranders thanks for the link! A translation in English would be wonderful....😉
It's unnecessary to discuss the best way of placing the UcD modules in the amplifier. The amp under review was one of our first samples for demo.
We would do it now in a totally different way (dual mono, BHC Slit foils, separate supply for the buffer op amp, etc....)
The purpose of this demo amp was to show how small you can build an UcD amplifier. And it's easier for reviewers to measure on a complete working amplifier, as on separate modules with transformers and power supplies.
Besides this we hardly find any influence when the amps are mounted very close to each other. However you WILL have problems when you are wiring the amplifiers in the WRONG way.
We have on our website soem recommondations for wiring.
Jan-Peter
Jan-Peter
Are you performing conducted and radiated EMI measurements on signal, speaker and power wires? Will you use any kind of common mode filtering to match SMPS "quietness" industry standards? That's important because any RF component radiated by wirings will be dependent on the audio signal, and it will be demodulated and turned into audio when picked up by other circuits.
By the way, one trick of which I'm taking advantage in high power class D is to use two series inductors laid in a dipole fashion. That produces inherent stray flux cancellation in the far field.
Jan-Peter said:Besides this we hardly find any influence when the amps are mounted very close to each other. However you WILL have problems when you are wiring the amplifiers in the WRONG way.
😉 endless discussion
Eva said:Are you performing conducted and radiated EMI measurements on signal, speaker and power wires? Will you use any kind of common mode filtering to match SMPS "quietness" industry standards? That's important because any RF component radiated by wirings will be dependent on the audio signal, and it will be demodulated and turned into audio when picked up by other circuits.
The EMI performance of the UcD amplifiers is very low. Meets easy all standards. We do not use extra common mode filtering.
Our new OEM version (dual UcD180 on one PCB), is having such a low EMI in the 70-110MHz area that these amp can be build together with an internal FM tuner.
Jan-Peter
The reviewers were greatful to have a working amp. They were also quite pleased, not as skeptical as when they tested one of your competitors (I'm sure you know who).Originally posted by Jan-Peter [/i]
This will save a lot of grief and in particular for the builders. Wiring is not obvoius for a "normal" person and correct wiring is _very_ important if you want to take full advantage of the modules. Compare all gainclone builder with not so good wiring directions. Most problems there is hum problems due to uncorrect wiring. Don't forget to make a sketch for stereo and one transformer.Originally posted by Jan-Peter [/i]
Correct wiring is of utmost importance but there is no golden rule what's best for any situation. You need a proper wiring scheme that will satisfy the basic needs but than there is the fine tuning, even if it changes the whole basics of the scheme, and here the differences are more present when done right for that situation.peranders said:This will save a lot of grief and in particular for the builders. Wiring is not obvoius for a "normal" person and correct wiring is _very_ important if you want to take full advantage of the modules.
Some of our new OEM version;
http://www.hypex.nl/UcD182.jpg
http://www.hypex.nl/UcD402.jpg
You can see that the cols are quite near mounted to each other. We do not measure any real influence between the two amps.
I am hihly looking forward to the English translation of the Danish review!
Regards,
Jan-Peter
Regards,
Jan-Peter
@Jan-Peter: Will these little beauties be availeable to non-OEM customers in the near future?? Please??
Nils
Nils
No, I am sorry these are only for OEM customers. The UcD402 is used in our soon-to-be-released 800W subwoofer plate amp. And is used in a www.hevos.nl Bassgitar amplifier.
However there is not really a new thing. With two UcD180 you have one UcD182, and with two UcD400 you have one UcD402.
I am glad you like them.....😉
Jan-Peter
Jan-Peter
- Class D
- Hypex UcD400 reviewed
