Uneven voltage on PS
What causes an uneven voltage output on a +/- supply...
This should be a no-brainer but I have tranny of 30VAC and voltage of 40VDC. No problem. But it is +5VDC to GND and -35VDC to GND.
Tranny to bridge then to a couple rows of caps. GND comes from AC GNC "down the middle of the caps...
GND has to come from a source of some kind, the capacitors do not work well as a voltage divider as you have found. It should go to the centre tap of your transformer. If you have none, you would have to do something like a voltage doubler arrangement or a supply splitter circuit afterwards.
How much current do you need this supply to provide?
I have no center tap...
Ah ha!
But I have made this 30VAC from two transformers of 15VAC... I guess I ought to connect the GND to the point where I connected the two trannys. Right?
Anyway, it would be nice to know the alternative.
A couple or three amps I reckon...
That would be plenty.
Thanks for the physics lesson!
