Reforming capacitors?
I am reforming capacitors for the smoothing banks of a variety of amps. Most are new old stock 2 to 3 year old. Some are much older and been out of use for 8 years.
Can I reform upto working voltage with a 1M2 series resistor without any risk?
Can I use a higher charging voltage and take the caps off charge when they reach working voltage?
Is there a risk of not reforming properly if the charge period is shortened to less than 24hrs or 12hrs?
Can I reform, slowly, to higher than working voltage, IF the reforming current stays low?
I'm thinking working voltage +10% through 1M2 resistor.
I didnt know you can reform caps.
I found this article
Steven W. Moore - Reforming Capacitors
At bottom of his page are two reference links, about same subject.
more links:
http://ed-thelen.org/1401Project/TricksForCapacitors.html
http://www.chemi-con.com/u7002/toc.php
http://www.vmars.org.uk/capacitor_reforming.htm
http://www.angelfire.com/electronic/funwithtubes/Restore_cap.html
.... and from USA
DEPARTMENT OF DEFENSE
HANDBOOK FOR
STORAGE SHELF LIFE AND
REFORMING PROCEDURES FOR
ALUMINUM ELECTROLYTIC FIXED CAPACITORS
http://www.dscc.dla.mil/Programs/MilSpec/ListDocs.asp?BasicDoc=MIL-HDBK-1131
