If some young go-getter around here wanted to embed a P-Brain Intelligent Projector Controller into his/her projector design, I would be willing to sell them a pre-programmed controller chip, and a schematic really cheap.
You will need to have Electronics knowledge (Schematic Reading/Soldering/PCB prototyping/etc) to get it to work!
There are also several other components you would need to buy in order to make it work! like (Relays/Resistors/Capacitors/Crystals/etc) Total cost should be around 80 bucks american... or there abouts (if you use 20.00 each solid state relays with embeded circuit breakers like I did, instead of taking a cheaper mechanical relay route)
HARDCORE ELECTRONICS GURUS Only!
If you want to find out more about what the P-Brain is...
http://www.diyaudio.com/forums/showthread.php?s=&threadid=62055
