The softstart allows 5A current until the relay clicks in.
I am running +-56VDC rails with 180,000uF capacitor bank on one amplifier and +-80VDC rails with 120,000uF capacitor bank on another amplifier. The transformers are probably rated at 625VAC.
How can I calculate how much time is necessary to fill the capacitors up?
Should I set the relay to 2 seconds? 3 seconds? 5 seconds?
Regards,
Bill
Regards,
Bill
I'll guess your diodes are >> 10 A which means they can cope with 100-200 A short term. Therefore you'll need to limit the transformers inrush current only and this will take a rather short time. 1 second is enough in order not to blow your fuses in the wall.
Thanks Peranders.
My worry is not about the fuses or the diodes. It is the power switch. Without the softstart, the amp has been running for over a year, using the wall socket switch. The house lights are dimmed when it is powered on, and sometimes sparks came out from the wall socket. A number of high power rated switches installed on the amp all have been destroyed. I hope the softstart will protect the switch and provide stability for many years to come.
Regards,
Bill
Regards,
Bill
soft start
If you get sparks from the wall socket you have a fire hazard that should be corrected ASAP ! !
This can cause a fire ! !
Get a better wall socket or have an electrician install one, your house will thank you.
Ed
Ed
if sparks are all you need to get rid off, why cannot you just parallel a small capacitor (like 0.01u 600v) to the switch? it will take care of your sparks quite well.
The inrush current is due to caps not fully charged so can anyone tell me how long it will take to fully charge the caps?
tlf9999,
My amps will have the X2 cap on the main so I guess that serves the function of your small cap.
Regards,
Bill
tlf9999,
Regards,
Bill
The inrush current consists of two components, magnetizing the transformer and charging the caps.
The volatge increasing speed is:
I/C = V/s
So the answer is one or two mains periods => 17-34 ms if you exclude the softstart.
May I ask why you have so huge smoothing battery? Do you have a low power supply rejection ratio of the amp? "Much" isn't better always. The drawback is more harmonics and more losses in the transformer. Most likely your transformer will be able to deliver half of the VA rating due to the extra losses.
I/C = V/s
Peranders,
That is because
(1). The caps are pulled from an old amp that sounded very good so in a way it costs me nothing to put the extra uF in; If I don't use them they will be wastes.
(2) If it sounded very good with 180,000uF in the old amp I presume it is OK with the new amp with the same transformer; and
(3) The amp is to drive an averaged 3 ohm load (minimal 2.5 ohm) and I play organ music.
Question:
I am aware of possible higher harmonics but not transformer losses due to higher filter capacitance. I will be very interested in your explanations or pointing me to the relevant articles on the web.
Regards,
Bill
That is because
Question:
Regards,
Bill
second time today I have said use http://www.duncanamps.com/psud2/index.html
You can set the time period to allow you to examine in detail how the currents and voltages vary during the charging and subsequently.
Peranders,
Thanks for the formula. That works out 2 seconds to fill out 180,000uF caps to 56V with 5A current.
Any enlightenment on how big caps cause transformer losses?
Regards,
Bill
Regards,
Bill
- Setting the relay time on softstart
