Hi
I've made a simple discrete triangle generator if any of you are interested.
With the current values it's osscilating at 1kHz. Decresing C2 will increese the frequency.
The schematic:
A simulaion:
I've attached the Orcad 10.3 project files.
Enjoy
Best regards
Kaspar Sinding Meyer
The schematic:
A simulaion:
Enjoy
Best regards
Interesting...
Have you tried to put it to oscillate at about 250-400KHz? How does the triangle look like?
Best regards,
Pierre
Best regards,
Pierre
Good question. I have tryed that, The triangle wave gets a little bit idstorted in the bottom @ 400kHz, but else it looks fine. However I think that can be solved.
Okey heres what you'll have to do to make it work @ 500kHz . Change R7 to 1.5k, R2 to 2.2k and C2 to 330p. To improve linearity decreese C7 to 47p.
This is my simulation results:
One way to evaluate the linearity of the triangle wave is to look at it's derivative. One should expect a pure square wave. This is my results:
No I haven't yet used it, since I designed it yesterday.
Right now I'm using a solution with one comperator and a couple of BJTs. I've posted the design here:
http://www.diyaudio.com/forums/showthread.php?s=&threadid=54263
