Did you Google?
I know there's a lot out there.
I ones bookmarked a site with almost everything from Heathkit but can't find it at the moment.
Edit: This fellow seems to have it.
Homepage: http://www.d8apro.com/
/Hugo
/Hugo
Took a quick look at the schematic, and the feedback is DC coupled. Only a cap, huge 220uF back to back at the input. The power supply is a bit odd, 4700 uF on the driver stages but with RC filters also.
Noticed that the spec -3dB point is .1 Hz on the low end, so it will pass everything from upstream.
Pete B.
Pete B.
- Schematics for Heathkit AA-2500 Power Amp?
