Dis is the lightbox for ma nu psone-project. 4 ¾” x 4 ¾” x 2 “ (WxLxD)
The components are as follows:
- “stripped” ( removed glass) hqi-t 150 W (Osram)
- “dremeled” par20 dichroic ( cool beam) reflector ( Osram No.: 64836 SP or FL)
- socket GY 6.35 mm
- 1 fan grill 80x80
- brass hinge
- blower ( radial)
- alloy 0.8mm
The advantages are:
- less lcd-heat due to the dichroic reflector
- small dimension
- focusing
- built in uv-stop glass
- high efficiacy (all light goes through the condensor)
- no need for a g12 socket ( saves money)
- no additional ir-filter necessary
costs: around 25 Euro = 30 bucks
- par 20 cool beam = 9 Euro ( german webshop, hard to find)
- hqi-t @ ebay : 13 Euro( regular price around 25-30 Euro)
- blower : nidec gamma 26 = 1,95 Euro( www.pollin.de)
- alloy: left from my lilliput project
- socket gy 6.35 : 1 euro (www.reichelt.de)
How to remove the glass of a hqi-t to get this tiny lamp?
Thx to ma friend “bonsaijogi” for the pix:
So I got my dremel spinning and removed the base.
Here you can see the fitting of the „stripped“ HQI-T into the cool-beam-reflector.
here is an older pic from inside ( with another reflector) just to show the mounting.
and now .......spot on
the circle is around 5 ½ inch in a distance of 3 ½ inch where the first fresnel will be placed. ( well that depends on focusing and condensor)
Isn’t it nice?
To be continued............
