So simple it should be illegal! I'll be trying that in the next days! I wonder why I never tought of it before...
Thanks,
Sébastien
Thanks,
Sébastien
The same trick also works with Lexan/Plexiglas, etc. Or you can clamp a piece of wood on top.
Grey
Grey
Damn good tip.
A tip for this tip - don't use electrical tape, the heat generated by the cutting process usually melts the tape's glue, sometimes even the tape, then you get stuck cleaning all that gooey glue gunk off your stock which takes just as long as deburring the edge. Automotive masking tape(the lime green 3M stuff) works ok for me.
i use electrical tape and it works fine with my band saw, i guess it doesnt get as hot.
Illusus,
did you get my email from a few days ago? im finally going to go through with getting some stuff for you, its not just a bluff this time 🙂 whenever you get the chance, let me know what else you need from me.
Illusus,
Yeah, I got your mail, I've been gathering info on completing that for you. I'll give more detail in an email(tomorrow).
not a problem. just as long as i dont have to look somewhere else. im trying to move along all my projects quickly now. i just found about $500, so i have the funds to pretty much complete all my projects! i also got access to a mill, yippee!
Joined 2002
cowanrg said:not a problem. just as long as i dont have to look somewhere else. im trying to move along all my projects quickly now. i just found about $500, so i have the funds to pretty much complete all my projects! i also got access to a mill, yippee!
Want to do mine too then >?
hehe, sure! if you lived close, i would gladly mill your metal for you. but shipping would be pricey. i need practice at any rate.
im going to be a total loser and do a ton of unecessary parts for my pre-amp, just because i can, and because it will be nice to get the practice.
i just got doing the solidworks files and analysis, and it looks like my aleph2s will be weighing in at around 100 pounds per chassis, maybe a bit more. not too shabby. gonna need that money for all that metal and fasteners!
Joined 2002
id like to start mine but that will be soon. gota get my parts here first. : O ) just working on my gain clones for now.. : O )
J'
J'
Joined 2002
low cost simple for me to do.. cheap. and keep's me out of trouble : O) if i had all the tools yu did id be workin on my aleph's and newer project's such as speakers and pre-amp : L O )_
this is true. they are cheap and easy to do. but my aleph3's didnt require hardly any tools and were very very cheap to build too.
As an avid woodworker, I feel compelled to ask the same thing I would on a woodworking forum:
*ahem* "Safety guard removed for clarity, right?"
(Not the fault of the thread starter, naturally. The folks at the site should have noted it.)
Do yourself a favor and follow all safety precautions, and use your safety gear when using power tools.
(/soapbox)
(/soapbox)
eLarson said:As an avid woodworker, I feel compelled to ask the same thing I would on a woodworking forum:
(/soapbox)
As an avid metalworker, I can't imagine producing quality results with safety guards in place. All my safety guards are removed (or were not installed in a first place).
Here's a tip I just learned today. Don't use any liquids for sawing. Sawing wax is a lot better and it isn't messy like liquids. You just rotate the blade and stick the block of wax to the blade. When it get's warm it spreads to the blade and forms a greasy coat.
"*ahem* "Safety guard removed for clarity, right?"
(/soapbox)"
Heh. "It's coming right for us!!"
(/soapbox)"
All safety devices should ba outlawed. It slows Darwinians selection. People who can't work with eqquipment and not loose didgits should loose them, making themselves less atractive to potenetial mates, thus preventing the spread of the careless genes.
Yeah, this brings some old memories: http://www.amazon.com/exec/obidos/t...f=sr_1_1/104-6600787-1026352?v=glance&s=music
- Here is a great tip for you guys building aluminum chassis for your amps
