I wanted to start a new thread in lue of posting in so many others to get out some information. I work for a large consumer electronics store, and we take in hundreds of salvage rear projection tv's. Since it is salvage, I can get any parts that I want, so I figured that I would look for first surface mirrors. I now have several large first surface mirrors that I will cut to size for anyone who needs one. They are good quality most of the mirrors come out of older high-end crt big screens. If anyone is interested please send me an email with your info and the size mirror you need and I will respond as fast as I can. Thanks and good luck!
Hopefully you can help me with information
I have a Hitachi 50" rear projection tv.
The mirror shattered in the back of the TV. Ive called Hitachi and asked them what the mirror size if so I can go and buy a mirror to replace the one that broke.
Well Hitachi doesnt know the measurements of the mirror all they can tell me is what the replacement part number is. Ive also called a couple Television repair shops and they tell me if I bring it in they can fix it but wont tell me the mirror measurements.
I can fix it myself if I knew the exact size of the mirror. I measure the brackets rhat holds the mirror and what I came up with was
31 1/2" wide by 27 1/2" heigth.
So can anyone tell me what the exact size of the mirror would be, I think Im close but may be off a little. I have tried on other forms but I was reffered to this form board that someone here should know.
By the way the model of TV I have is Hitachi 50UX52B if that helps you in telling me what the size should be.
Dan
Dan
