Whenever I make something I'm usually asked to explain the "how's and why's". Usually I end up polluting another thread...so I made a thread for this purpose.
The latest project is a tool for winding big inductors.
The pics can be found at www.briangt.com/gallery/magura
Magura
Magura
Just added photos of the just made copper heatspreaders/- heatsink mounts. There are 24 of them at approx. 1kg. a piece.
http://www.briangt.com/gallery/magura/PICT0061
Machined to fit the round box for the ZV7 project.
Magura
Magura
Machined a pair of aluminum inductor mounting brackets, for 2.2mH air core inductors for the PSU.
This should result in a solid mount and excellent heat transfer to the chassis, which is more or less just one big heatsink.
Added a couple of pics to the gallery.
http://www.briangt.com/gallery/magura/PICT0079
http://www.briangt.com/gallery/magura/PICT0080
Magura
Magura
Now the time came for a little progress in the 40 step attenuator project.
http://www.briangt.com/gallery/album05
Further description to come.
Magura
Magura
Theese contact plates have been machined of 3mm double sided PCB. The outer circle of contacts will be 3mm, the inner circle will be 2.5mm. Outside diameter is 85mm, the center hole is 36mm, to accomodate a 20mm axle and the mount for the spring/-slider assembly.
The whole this is to be mounted in an aluminum cylinder, which is stack-able, in order to allow for an unlimited number of decks.
Magura
Magura
Machined the bolts and nuts for mounting the heatsinks on the ZV7 project. I forgot to make a photo of the wrenches made for the bolts and nuts...but they do exist
http://www.briangt.com/gallery/album01
Also got round to machining the housing of the attenuator switch, will post photos later (left the ithems in the workshop).
Got the silver for the switch today as well...around 300 grams of it exactly enough for 9 poles of 40 steps.
Magura
Magura
DIY 40 step attenuator, update.
Got around to finishing up the housing for the 40 step attenuator switch today.
Everything is to be assembled with M3 bolts. A pair of deep groove ball bearings will keep it running smoothly.
Now the silver contacts and the sliders is all thats left....should be a walk in the park from here ...and the spindle naturally...
A couple of pics, oily fingerprints and all
http://www.briangt.com/gallery/magura-40stepattenuator
Magura
Magura
pinkmouse said:
So, are those grooves milled into your inductor brackets actually matched to the windings of the coils?
Yes, it seemed to be the easy way to get good contact for the sake of heat transfer.
I tend to choose milling over turning for the sake of convenience, might as well go all the way then, and take any advantage possible.
Magura
I just realized that I forgot to post the link for the pics....that link just might make it a little more interesting
http://www.briangt.com/gallery/album02
Magura
Magura
Just finished the 600+ solder joints to mount the silver contact pins, what a nightmare
http://www.briangt.com/gallery/magura-40stepattenuator/PICT0002
http://www.briangt.com/gallery/magura-40stepattenuator/PICT0006
Anyway, I hope to machine the sliders during this weekend, and to have a working 40 position, 9 deck switch, sometime next weekend. Depending how much trouble I'll have finding the required values of the resistors.
Magura
Magura
Devil_H@ck said:
Why do you need a 9 deck switch?
The first 8 are obvious I guess The 9th is for position indication, as each position will have a led.
I figured that would be a good indicator when using the remote to control the volume.
Magura
Re: Contacts
The silver contacts are made of 935 silver wire, as you most likely know it's a silver/ copper alloy. Since the switch will be sealed, there is little point in using gold, as far as I remember it silver is one of the best switch contact materials, and can't be bettered significantly by any material. What have to be kept in mind is also that there is more than 250grams of silver in those contacts, which set me back 130 euro....I don't even want to think about the price if it had been gold
I have bought the wire through a jeweller, as they get it much cheaper from the wholesales than we do.
Magura
kamskoma said:Hi Magura,
Where do you find the silver contacts? is it possible to find gold contacts or a alloy with gold as main part.
Kamskoma
Magura
- Design & Build
- Parts
- Project progress report
