I’m thinking of trying one of the Volt woofers in a new project and was using winISD for modeling. Most Volts seem to model as predicted except for the b2500.1 (ironically the one I was planning on getting). I’ve heard great things about this driver but can’t seem to get respectable response. Am I missing something? Here’s the T/S
Fs 25
Qm 1.4
Qe 0.25
Qt .21
Vas 51 L
Xmax 5.5mm
Sd 299 cm2
Le 0.8 mH
Re 5.9
BL 20.3
I’ve search the archives and found praise for this woofer in 70l tuned to 30hz but I doesn’t model like that.
TIA for any help.
Fs 25
Qm 1.4
Qe 0.25
Qt .21
Vas 51 L
Xmax 5.5mm
Sd 299 cm2
Le 0.8 mH
Re 5.9
BL 20.3
TIA for any help.
I haven't modelled it because I can tell from experience of modelling similar specs that the low Vas and Qts in a 70 litre box will give a very 'dragged out' response. Ideal alignments will use a box in the range 25-50 litres, I reckon. If you drag the response out by using a large box I think it worsens the transient response and you get slightly sharper roll-off. Overdo it and you get a dip in the response followed by a peaking just before the response plummets.
You are correct it does not model well in 70L with 30Hz.
IMO anything with box volume > Vas of the driver
there is always a better driver choice out there.
I think you have to realise studio drivers are optimised
for very high levels, so even a 10" would not be used
to go that low as it would run out of excursion.
Volt drivers have a reputation of not being able to
be aligned to go particularly low in the bass, seems
to be another case in point.
🙂 sreten.
🙂 sreten.
Thanks for the response(s).
I just found it strange that many people feel the b2500.1 to be one of the best 10 inch woofers made but it models totally different than any of the other Volt woofers (they model well). I thought the B2500.1 was the woofer used in the rel subs. Obviously eq’ed but still….
With 5.5mm of xmax thats going to run out of excursion pretty quick if EQ'd to give good bass flat to 20hz as per sub.... I doubt Rel use this driver.
jonk said:Thanks for the response(s).
REL dont just use Volt anymore,i am told.
The b2500.1 has a very dry sound quality and its good, but am not one of the people that think its the best, Wilmslow audio may disagree.
Looks like a fine EBS to me once the cab is critically damped to flatten the Fb peak. This yields a very 'tight' ~aperiodic alignment of the type best suited for blending to a horn or electrostat, think TL with gain (see sim). Terrible efficiency, but otherwise very nice if it meets the needs of the app.
GM
GM
That is an interesting set of compromises GM. Maybe one I could live with. I would be using this woofer mounted close to the floor, up to ~180hz, crossed over to mangers. I can drive them with a Bryston so power isn’t an issue. Plus my room is peaky at 100hz anyway. I was going to use a sealed low q alignment to compensate for room gain.
A few questions (and please forgive my ignorance, I am a beginner) if you don’t mind?
By critically damped do you mean keeping the peak at the bottom of the shelf flat?
I’m having a hard time following your sim as far as tuning is concerned.
What’s the volume of the box?
Are your stuffing the vent?
If I sim it, I tune to 25hz in 30L box but end up with a 20” port. How did you arrive at 3” port 4 ½” long? Interesting results though. 25 Hz is only 5 db down from 180hz with max spl of 104db (at 25hz!) from 30L.
Maybe Rel did use this driver (well two of them actually).
Paradise ice. Those are some crazy looking drivers on your page.
Thanks all.
Thanks all.
jonk said:. I can drive them with a Bryston so power isn’t an issue. Plus my room is peaky at 100hz anyway. I was going to use a sealed low q alignment to compensate for room gain.
Your no novice if you have Bryston!
I like the Volt but they can be so fussy!
It sounds like your Box design is almost a homage to REL home subwoofers but smaller?
Do you guys like the Mangers in Canada?
Sound like your a pro to me!
OK, but the lack of efficiency and sufficient Xmax is, so I recommend using two with twice the Vb/vents/channel.
Then EQ will be required to flatten it since either of these rising response alignments will just aggravate the problem.
If I did, I wouldn't be here. 😉
Correct.
Sorry about that, but to model the effects of high aspect ratio cabs required MJK to use internal dimensions instead of net volume (Vb), so net Vb in ft^3 will be the length (L)*SO or SL/1728 since it's a straight tapered (rectangular) cab, or ~2.471ft^3, the referenced 70L.
No, the entire cab with 1.0lb/ft^3 of polyfil, though somewhat less is required if acoustic fiberglass is used.
Small cab tuned low = huge vent required if it's to be driven to its limits with low distortion. Larger cab combined with stuffing dramatically lowers vent mach, allowing a smaller/shorter vent to be used.
This alignment is what Focal calls a Daline and is very similar to Wayne Parham's Pi Align. Damping the long vents are 'de riguer' for a smooth, well damped wide BW response.
GM
Correct.
GM
Thanks for the responses and help guys.
Paradise ice- Everyone in Canada has a Bryston. They come in a pack with our toques and double doubles ;-) (Sorry for the regional humour).
Happy Canada day to my fellow Canadians. As I type the Snow Birds (Canadian fighter jets for the rest of the world) are flying just a couple hundred feet over my house as they turn around to swoop the parliament buildings for the celebrations.
- Can’t get this Volt woofer to model.
