Tool for producing an LCR network that = a speaker+box?
Where can I get some software/.xls/calculator that creates an RLC network that emulates any particular loudspeaker, given the T/S parameters and box size?
Basically I'd like to be able to model the shape of a speaker's impedance curve with a few Ls and Cs and Rs.
Thanks!
CM
The impedance will be Re in series with Le (which is lossy) in series with a parallel RLC resonance circuit. In this parallel circuit
R= (Bl)^2 / Rms
L= (Bl)^2 * Cms
C= Mms / (Bl)^2
Where Cms is the compliance of the driver, Mms is the total moving mass of the driver, and Rms is the total mechanical resistive losses of the driver. In case of a closed box, it can be seen as if the box modifies Rms and Cms, so the effect of a closed box can be included by changing these values. Other kinds of boxed will need another type of circuit diagram than this.
HTH
