Hello everyone...
Has anyone ever used one of these:
I purchased 4 last year and modified one so that I could mount an AV800 (Anthony Holton) on each side.
These heatsinks are made by Wakefield Eng. Inc and are MOD. FCA-800, they measure 12 inches (30.5cm) long and all 4 sections are electrically isolated from each other. My aluminum inserts basically split the heatsink into 2 halves electrically.
I was wondering if anyone knew any more information on these, specifically their thermal resistance with a 80cfm fan attached. Any info would be more than I have, here is the actual extrusion from wakefield, but I just don't know how to figure out if what i have done will meet the requirements of the AV800, Anthony specifies .2degrees/watt or .5 degrees/watt with fan cooling. Thanks!
Joined 2002
You can find the A-40 article by Nelson Pass at his DIY site. He uses the same heatsinks for his A-40 in the article. He also talks a little about class A heat and heatsinks.
I found an equation for forced convection thermal resistance:
272.16/(A*h)
Where A is the surface area of the extrusion in sq in (get that from the data sheet.....)
And h is the heat transfer coefficient.
Since you have a 12" long extrusion, and probably not a hurricane blowing across it..........figure h is around 1. That will get you close. The value of h rises to 2 at a flow velocity of 400 ft/min.
Jocko
272.16/(A*h)
Jocko
http://www.fischerelektronik.de/download/download_fr.htm is more - i think - what you are searching for, especially the the D Gruppe.zip under "D".
Using one myself albeit only with a length of 2 units (71 mm.). My fan is spinning only enough to make it start - and then a tad for safety. Two 2N5884/2N5886 on each arm and each running at 0.5 A. /10 V. Works perfectly and without noise from the fan.
SWEET!
Thanks!
Thanks!
boholm said:http://www.fischerelektronik.de/download/download_fr.htm is more - i think - what you are searching for, especially the the D Gruppe.zip under "D".
New question.... SAME TOPIC
Has anyone ever mounted a fan at either end of a tunnel and have the second fan come on at a preset temperature.
Does having the first fan running while the second is unpowered reduce the efficiency of the first by a lot?
I was just considering having the first fan on all the time or say come on at 50°C and the second at 65°C and shutdown at 80°C.
Any thoughts?
Thanks again!
Any thoughts?
Thanks again!
It will put drag on the airstream, not something needed when you need to get air out as quickly as possible once it's heated up. I don't know why people would want a temperature-regulated heatsink anyway, to ensure life is always short? Blast it with as much air as you got.
Tim
Tim
I was hoping to keep the fan off when using the amp at low listening levels so I didn't have to listen to fan noise.
Sch3mat1c said:It will put drag on the airstream, not something needed when you need to get air out as quickly as possible once it's heated up. I don't know why people would want a temperature-regulated heatsink anyway, to ensure life is always short? Blast it with as much air as you got.
Tim
- Design & Build
- Parts
- Heatsink math gurus look here.
