http://www.brndog.com/SingletoDual.html
Thanks Sonny. Hope they are of use to the community. They came out well, only one minor error, the IC2 silkscreen is missing its circular index in the lower left corner, which got left off the BrownDog master. They will probably fix it for the next batch. 🙄
Nice. Just put in my order. Trust OpAmp orientation is easy to sort by following the traces. Norman
The orientation of the text letters is correct, and both sides have an auxillary dot left of pad 1 in addition to the bigger circular index inside the rectangular chip outline.
Looks nice! Where does one get those single pins? Do they fit into machined turned hole sockets?
I use DIP8 pin to solder adaptors where the pins look thinner and more pointed. It is very easy to handle but with the plastic connecting the 8 pins, there is an extra 3 mm path to the PCB.
Greetings,
Eric
Greetings,
Eric
Those are machine press-fit pins. They are not intended for manual installation, as far as I know. The adapter is available without pins so you can install your own. Digikey sells pins if you are so inclined, however, I suggest getting adapters with pins installed.
I have tested the new BrownDog adapters with AD8610 and AD825 opamps. Both sound great. The AD8610 might be a bit more refined, however the AD825 puts out more current, which might be an issue if driving low impedance headphones directly, as in a CD player headphone output stage. Listen for yourself. 🙄
The AD825 max supply voltage is ±18V, the AD8610 is ±13.6V, so be sure to check the power supply if you are swapping opamps, there may be some ±15V supplies out there.
Just installed these with 8610s
They are used as the I/V converters for my SACD player replacind opa2604s.
They worked perfectly. Delivery was super fast from BRN Dog and they are way cheaper than the LCaudio modules.
I didn't need bypass caps on my system.
The BrownDog adaptors are terrific! Works as advertised.
Recently swapped out the 5532's in my CD player with AD8610's/adaptors. The adaptors made the job a breeze!
Thanks, morsel.
Thanks, morsel.
--------------------------------------------------------puppyslugg said:The BrownDog adaptors are terrific! Works as advertised.
Thanks, morsel.
The AD 8610s are even better if you current load them.
On a separate point, does anyone know if there are coupling problems between channels if one current loads dual opamps ?
fmak said:
"The AD 8610s are even better if you current load them."
Agreed.
Just waiting for morsel's cascode current source opamp adaptor. 😀
Cascode current source opamp adaptors!
Are these to be available through brnDog directly or do we have to order these through Morsel? What is the estimated ETA?
Morsel...any thoughts on an adaptor that will take an LDO?
Might be crazy idea, but just thought I would ask.😀
The BrnDog adaptors are great!!!
Hee hee! 🙄
I designed the BrownDog opamp adapter as a community service, but I do not make any money from them, nor do I sell them.
Get them directly from BrownDog:
http://brndog.com/SingletoDual.html
http://brndog.com/priclist.html
Order the version with pins unless you know you don't want pins. The pre-installed press fit pins are quite good and save you the trouble of installing your own pins. They are $2.39 each with a minimum order of 5, or $1.59 each without pins. Quantity discounts are available.
BrownDog has a secure page for online ordering. Orders are filled quickly and shipped all over the world via priority mail, UPS, or FedEx.
Phopson, about the low drop out regulator, that is rather specialized. Altering the supply voltage for the opamp would require a much bigger adapter. I know you love the AD8610. You can try lowering the power rails that supply the opamp from 15V to 12V, the rest of the player might still work fine at the lower voltage. I think that would be the easier approach.
Alternatively, you could use the AD825 or AD823 if you want better high end detail than the AD8512 you are using. Don't hold your breath over the new FastFET AD8065, it probably won't be as good as the AD8610. Still, it will be interesting to check out.
ad8620 now available
Hey all,
the ad8620 (dual version of ad8610 is now available)
cheers😀
http://products.analog.com/products/info.asp?product=AD8620
Hey all,
cheers😀
- single so8 to dual dip opamp adapter available from BrownDog
