I have made some new code to the speaker design program.
It is still quite much non-functional, but here are
few items that work (mostly):
- Driver loading (xml file parsing) (XML parsing done with libxml2, http://www.xmlsoft.org)
- Driver saving (xml tree writing to disk)
- Frequency response calculation & plotting for closed box. (Plotting based on Qwt lib)
- Suse Linux 9.0 binaries work
- User interface (based on Qt)
We have now three contributors working with the software.
If you feel that you have some ideas that might help us,
feel free to join the project. For more details about
the speaker design program project, please see:
http://www.iti.fi/speakerdesigner
The project web page tells quite much the information you'll
need to become a developer for the project. This is
free software and the licensing model is GPL.
If you want to contribute just by doing driver specification
files, feel free to do the xml files. They are pretty simple,
there is an example of the fileformat on the project page.
By doing same kind of files, you can't go wrong. Just type
in your driver's parameters and it will work.
Best Wishes,
Karoliina
Best Wishes,
Karoliina
Joined 2002
like this?
<?xml version="1.0"?>
<driver_definition filename="TAD TL1601a.xml" name="TAD TL1601a" type="bass" author="Till Pape" version="0.0.1">
<parameters version="0.0.1" comment="thiele-small parameters">
<size value="352" comment="mm"/>
<type value="cone"/>
<other_info value="paper" comment="cone material"/>
<fs value="28" comment="Hz"/>
<qts value="0.31"/>
<qes value="0.32"/>
<qms value="6.8"/>
<res value="6.6" comment="ohms"/>
<lec value="1.7" comment="mH"/>
<vas value="304" comment="litres"/>
<bl value="20.5" comment="N/A"/>
<mms value="117" comment="g"/>
<znom value="8" comment="ohms"/>
<pistonarea value="0.0881" comment="m^2"/>
<max_shortterm_power value="300" comment="W"/>
<max_longterm_power value="150" comment="W"/>
<linear_xmax value="16" comment="mm p-p"/>
<nonlinear_xmax value="36" comment="mm p-p"/>
<airgap_height value="?" comment="mm"/>
</parameters>
</driver_definition>
http://www.pioneerelectronics.com/pna/article/0,,2076_4227_188486,00.html
is "size" this the opening or maximal diameter? baffle hole or outer dimensions?
What to do with specs i have but not in the example file? leave away? what to do with specs i don´t have? leave away? What about giving the source of data, like source: manufacturer, or source, measured, name, date. how to handle compression drivers?
<qts value="0.31"/>
<qes value="0.32"/>
<qms value="6.8"/>
</parameters>
till said:like this?
The size doesn't affect to calculations, so I haven't
decided yet.
You can invent tags by yourself, I may implement them
if I find them useful.
You can leave few parameters away, no problem.
Feel free to suggest new tags.
Best Wishes,
Karoliina
P.S. I tested the driver and it works. Thanks a lot!
P.S.2. All computers (many of them btw)
running Linux in our household 🙂
Joined 2002
Most of my friends use linux or unix.. almost none of them use windows maybe 2 out of all...
Linux is becoming more and more used..
I like the solaris in university most... the best on it is the admin.
No acess to the ftp, should i make some of these files and email them?
with suggested new tags:
<driver_definition filename="TAD TL1601a.xml" name="TAD TL1601a" type="bass" author="Till Pape" version="0.0.2">
<parameters version="0.0.2" comment="thiele-small parameters">
<application value="PA, Studio" comment="no"/>
<outer_dim_diameter value="400" comment="mm"/>
<outer_dim_depth value="167" comment="mm"/>
<qts value="0.31"/>
<qes value="0.32"/>
<qms value="6.8"/>
<cms value="2.761 comment="Mechanical Suspension Compliance""/>
<efficiency value="97" comment="dB at 1m & 1W"/
<magnet value="alnico" comment="no"/>
<voicecoil value="edgewise-wound" comment="no"/>
<information_source value="manufacturer" comment="website"/>
<date value="13.4.2004" comment="d.m.j"/>
<URL value="http://www.pioneerelectronics.com/pna/bsc/category/0,,2076_4211,00.html"/>
</parameters>
<qts value="0.31"/>
<qes value="0.32"/>
<qms value="6.8"/>
</parameters>
About Linux: Yes, Linux is gaining popularity.
But: Qt is cross platform toolkit and for example
MacOS X -version will be pretty easy to do.
Till: You can e-mail your files to me.
E-mail is:
karoliina at iti dot fi
(Change at and dot to @ and .).
Please zip or tar/gz the files first to avoid them going into to our
spam filter.
Best Wishes,
Karoliina
P.S. I don't like Unix System V and its derivative works.
E-mail is:
spam filter.
Best Wishes,
Karoliina
Some may know it as Android.
Linux? You'll have almost no user base.
Much better this way, this wide Win and Mac user base is so ignorant...😀
- Speaker design software progress update
