First off, I want to thank everyone who responded to my questions and everyone who has posted here. I did alot of lurking and searching. Most of my questions were found w/o posting a question.
Here is an update on my sub project, if you care.
Endtable style downfiring 118L 4" ported box tuned to 20.5 hz w/ a shiva 12 and pe 250w amp.
here is what the sub will look like completed.
here are some cabinet construction pix
step one
braces assembled and attached to 1.5 thick bottom
step two and three.
adding the sides.
step 4
ends have been add and waiting for the clear silicon to dry so I can put in the driver, amp and port.
you can see these pictures and others here:
http://dodgetrucks.org/cgi-bin/index.pl?user=66&cat=500&thumb=1
thank you all again, I will post again later w/ another update after I get it all assembled and tested w/ U571 depth charges.....
step one
step two and three.
adding the sides.
step 4
