Has anyone got an Eagle library that contains either the Texas Instruments PGA2310 or the Cirrus Logic CS3310?
If so, could you please contact me or post an URL or something?
It is not that hard to make them yourself albeit a bit counterintuitive. It is a 3 part process:
1. Make footprint
2. Make schematic symbol
3. Connect the two.
Look in the help files and you will get it.
Petter
1. Make footprint
3. Connect the two.
Petter
Thanks, I started creating it right away, however it might take a while before it's finished.
I'll put a link here once I finished it.
Ok, that was quite easy actually.
The DIP16 package seems to broad at first, but I checked it against a part with a DIP16 package that was already in Eagle and the pads are in the same place.
Enjoy: PGA2310 Eagle model
PS: If you find a mistake, please tell me! This was the first time I tried making a part.
Hi Devil_H@ck,
Have you a new link for PGA2310 model library for eagle because the link is down.
Thank you in advance.
bye
bye
. . . . And then you would know how to do it, and that it was right.
I, unfortunately, have gotten some pretty sketchy Eagle packages from others before. I'm not saying Devil_H@ck goofed his up, but I have gotten goofy ones before. Better to do it yourself and be sure.
David
David
Joined 2002
- Design & Build
- Parts
- Eagle Library Part
