...so the first channel is build and I am trying to fire it up (sorry, don#t have a digital camera (yet)). The setting is done for 100W with 8 devices per channel. I use hifizen's boards with some minor adjustments as discussed here in the board.
I use a variac to test it and so far I have only +-7,8 Volts put on it (with 22Volt the target voltage). Now, something very strange happens: Side A (within the same channel) works nicely and quiet while the other side (B) buzzes like hell.
When doing some measurements, I have 0,04Volt over the 0,33R resistor in the current source of A and only 0,004 Volt on side B, so side B does not draw the intended current. Before I now destruct the whole thing and check each transistor, I would like to get some hints from the group on that.
The input and output is without any load. So no input caps as I will have a balanced preamp with output caps and nothing at the output yet.
OK, did that, buzzes is becoming exremly loud, sounds like if you have something mechanical buzzing.. I measured as well the voltage across R37 / the 1k resistor next to the MPSA18 (in my case a BC550C): Side A (which is OK): 0,07V, Side B: 0,0134 V.
I have exchange already both bipolars Q8/Q9, but without an effect.
What voltages do you measure at R31 and R32.
As you say no output is connected, where does the buzz come from? The toroid?
I assume we both have the original AlephX circuit in mind when talking about device numbers?
/Hugo
/Hugo
What do you mean by "side" we are talking about 1 channel, right? Why would 1 channel have 2 sides?
Please describe what you are doing in detail.
I ask too where is the buzz coming from?
The half around Q1/Q2, the other half around Q10/Q11 😉grataku said:Why would 1 channel have 2 sides?
/Hugo 🙂
Yes, I mean with side exatly what Netlist describes: In Hofizen's schematic Q1/Q2 build one side and Q10/11 the oher side within one chammel.
No, the buzzing does not come from the toroid, it is absultely quiet. It come from the Mosfets on the heatsink, but only from those on one side
Over R31 I measure 0,025V on side B(buzzing) and over the same resistor R14 I measure on side A (quiet) 0,115 V.
Over the two 1K Resistors (R32/R15) I don't have a voltage on either side.
firing up
Please check the pinning for the bipolairs.
MPSA 18 is ebc, BC550 is cbe. Verify this in the datasheets before changing anything!
I have looked at Fairchild's MPSA18 en Philips BC550.
Hi there,
Did you check the insulation between the heatsink and mosfets?
Regards,
Remco Blankesteijn
Regards,
Remco Blankesteijn
I saw that the pinning of the BC550 is different when assembling it, so that should be OK. I will now check for the insulation as suggested.
No buzzing....
...ok, checked insulation..everything OK. HAving done this, I checked each mosfet for vibrations and....no one of them did anything, so it was finally the @!?%&# current inrush limiter I had before the transformer. Now with 12 V both sides work as they should...Have not the time tonight to finalze it (especially to get 0 DC at the output), but for the moment I am happy, thanks a lot folks !
Re: No buzzing....
However, it sounds strange to me that the limiter would only 'limit’ half a channel. Normally, when PSU's are faulty, both halves of the amp are affected. I still think half of that channel was not fully turned on. Please give us some more info about this 'special case'.
/Hugo 🙂
Happy you found it.Blitz said:..so it was finally the @!?%&# current inrush limiter I had before the transformer.
/Hugo 🙂
Well...that as well is strang, but I guess you hint on applying 12V min here is really making the difference...which I didn't do becouse the limiter was so loud that I was afraid breaking something and turned off quickly.
OK, I guess I work my way through...a hard way though.
After not longer having the problem above, I raised voltage further, until it started to smell and you heard things cracking.
Well...I am replacing all output-mosfest now(as some are broken and draw a lot of current)...found out that on one of the insulation was not OK and so the heatsink was under voltage...plus one soldering point which was broken...
OK, now with 12 V on the rail I have 0,12V over the 0,33R at the source on side A, but only half of that on side B.
Over the 392Rs I have as well a diffenrence: one has 3,53 V, the other 3,82 V, even though the 9610 have been matched closely. Maybe they have been damaged too ? the 100K trimmers don't help here really, the difference they make is marginal.
What would be your best shot ? Replace the 9610 or the BC550 first ?
Best Regards
Best Regards
Something tells me that the 9610 has more chance to be damaged than the BC550. Change them, you'll see immediately what happens.
If all parts work, I mean nothing is damaged it's still possible to have both sides behave different because of trimming pots and slight mismatches of resistors.
However the amp should produce music in a primitive way, and the DC and bias should be adjustable within reasonable limits.
/Hugo 🙂
/Hugo 🙂
OK, will do so. The resistors are all 0,1%, so I guess the pot adds more problems than solving it. But you are sure that the current drawn by each 9610 influences significantly the current drawn by the output-mosfets ?
Yes, this is very important and also has a big influence on the differential DC which is the DC seen by the load and measured between +out and -out.Blitz said:But you are sure that the current drawn by each 9610 influences significantly the current drawn by the output-mosfets ?
/Hugo 🙂
OK, I did in the meantime the following: Exchanged the BC550C (That was easy to do as I exchanged them before already and the leads where easy accessible) - no changes.
Cut the 9610 and soldered the left one to the right side and vice versa. Very interesting: Yes, the outout mosfets now draw on side B more currrent than the left side. But as well the ratio now (without connecting each 9610 onto the same heatsink) changed: before the change the left side drew three time higher current than the right side, now it is only 50% more on the right side than on the left side...
OK, taken this as encouranging signal, I started to increase voltage to approx. 18V on the rails which lead to something around 0,43V across the 0,33 source resistors (5Watt wirewounds). Shortly after that two resistors started to smoke and where gone. This happened last time as well when raising power over a certain level, so the problem can be reproduced (last time it killed as well the mosfets.) (Still without having a restor connect between the output as I think the whole think should not implode when no speaker is present).
So what happens here now ? My theories ( and I would be happy to understand your thoughts):
A- When increasing power, the resistors change their value (become smaller), which again raises current to a level which finally kills the reistor as well as the mosfet.
B- 5 Watt resistors are simply not robust enough to handle 1,5A and 0,5 Volt (should have been OK, right?)
C. The mosfet (044n) hates more than 1,2 A current and breaks and kills subsequently the reistor - I planned to use only 8 devices per channel with 100 Watt as this drives 1,5 A through each device @ 22V
D. The two mosfets destroyed are those, which have no direct connection to the BC550C, the other two survived - a co-incidence or clearly part of the problem ?
A) Not true, the resistor value increases or decreases only with a very small percentage when warming up. You could look it up in the datasheets if you find one. Look for ppm.
B) 0.43V/0.33ohm is 1.3A. 0.43V * 1.3A = 0.56W. 5Watt resistors for sure can handle this.
C) According to the datasheet the irfp044N can take 53A at 10V 25°C and 37A at 10V 100°C. You are far from there.
D) No idea.
You should definitely change the 9610's.
Measure each mosfet as stated in Remco's post.
Check for mistakes in your wiring. Take your time for that.
Try to launch the amp with output mosfets gates detached and measure and tweak till the voltages on both sides are normal.
That's about what I can think of for the moment, if something more comes to mind I’ll tell you.
/Hugo 🙂
D) No idea.
/Hugo 🙂
OK, found another faulty insulator ( but not under the two dead mosfets) which again has set the heatsinks under voltage.
The resistors died because the mosfets died before- So even with very little voltage I have now a couple Amperes over them, which extend the 5 Watt by a lot.
I will now exchange these nasty silpad 2000 insulators which simply cause only trouble against regular stuff.
- Help needed: Firing up the Aleph-X100
