Power from Aleph-X with 4 Output Devices Per Channel
Re: Aleph X spreadsheet
dshortt9 said:
You can figure the power with this easy spreadsheet. Here is the link http://www.diyaudio.com/forums/showthread.php?postid=101066#post101066
I tried, but then there is another spreadsheet too. How much power can a single irpf244 handle , in terms of heat ? I just haven't seen anyone post final results. I am trying to get an idea if its worth it to build a pair or not on top of the pair of aleph 2s that I am building. My speakers aren't that efficient, if i could get about 50 watts per channel w/o adding more output devices then i'll go ahead and build a pair 😉
