tweeter sub-in for HF2000 for Celestion Ditton 66
hello! and happy new year.
what do you mean by diyng? is there still some output?
maybe you could first check for bad connections at the tweeters pins, or a bad solder joint in the filter;
such things happen especially with old speakers (i assume it is the 1970' version)
if everything is ok, then try this link :
http://www.recone.com/classifieds/_disc3/000002d6.htm
but bear in mind that a filter is really dedicated to a specific driver and changing drivers should involve checking for alterations in the response curve.
docjowe
There's probably some bipolar electrolytic capacitors
in the crossover that have seen much better days.
Tweeters don't die slowly in my experience.
Also look for any corrosion if connectors are used.
Recommend new crossover capacitors and hard
wiring of all connections.
🙂 sreten.
