found: online source for duct seal
i have had some difficulty locating a B&M hardware store that carries 'Duct Seal'.
this stuff has been highly recommended (especially by dave/planet10) for various damping tweaks, i.e. on driver baskets, etc.
anyway i finally found a supplier here, at mytoolstore.com. they have 1-lb blocks in a carton of 10, for US$24, or 5-lb blocks in a carton of 10, for US$85.
hope this helps someone else who might be having the same problem as i.
/andrew
That is even the same brand i'm using right now 🙂
This stuff has been called magic by some. Absoulutly required on speaker baskets, and useful in many other applications too.
If you can find a local (wholesale) source it would probably be a little cheaper -- IIRC i pay about $2 CAD 1 lb at a time. 10 lbs will go a long ways....
made in IL.
dave
