Pictures of another TDA1543 coverter
stacky fingers
Great Job Fabian ! try to lower the voltage of your cooling fan ... only a very little air movement will be enough to COOL down your 1543 stack and so stabilizes voltage drifts .
Tip : 2.2 uF / 100Volt Audyn-cap KP-SN sounds great at the outputs . very nice balanced sound .
Happy Ears !
Also curious about 32 pcs. in parallel ? haha 😀
Fabian said:
thanks to all the available information on this forum, I was able to build a very nice TDA1543 DAC. Just have a look at what I’ve done:
http://www.geocities.com/tdac1543
Enjoy the pictures….
Hi Fabian,
Thanks for the kind words on your website. I even did not see your name!
What puzzles me is that I see no coils in the oscillator for the asynchronous reclocker. You did use a lower frequency?
Did you use the triple Darlington for the supply?
Kind of funny to see how ways diverge starting with the same DAC as I am currently using only one TDA1543 at +5V and no reclocker with I2S direct. As output cap I am using Audionote paper in oil, copper foil. Active conversion is done with OPA604.
I have checked your website and you did nice work. What I like in particular is that you did listening tests bewteen the different versions. You liked the passive version best. I do as well !!
The are others here (Elso just replied before me) who are done other opinions..... but are not as clear as you are on what you exactly did.
Elso, could you enlighten us a bit on why you have been choosing for active I/V ??? What were the listening test conditions you had and what were the results ???
That would be really helpful !!
Doede
Thank you all for the kind replies.
@ Happy Ears
The fan is already running below 5V. The noise is not disturbing, but it would just be nice to have a dac without noise. And I surely will try other couppling caps.
@ Elso
Do you mean L1 and L3 on your circuit? The two beige parts are L1 and L3. R2 and C1 are placed underneath. I used a 100mhz quarz.
@ Lucas
I used the tripple Darlington supply with TL431 regulator. Here's the straight link:
http://www.diyaudio.com/forums/showthread.php?postid=92850#post92850
And the way I did it:
http://www.geocities.com/TDAC1543_6/
Fabian
Fabian said:
@ Lucas
Fabian
Thanks Fabian,
I will build this PSU also.
I have just received the Doede Douma PCB's, (http://www.dddac.de/ma_dac21.htm) and I want to use them in combination with your 3 PSU approach instead of battery-supply.
I have two questions though:
Should I leave out the TL 431 and the caps and resistors that were planned for the DDDac PCB, when I enter the 5 VDC and 8,5 VDC from your PSU, or would there be any benefit from extra regulation on the DDDAC PCB....?
What voltage-range would do for you PSU's?
You write 16 Volt on your scheme, but what is the minimum voltage for the transformers of the 5 V and 8,5 V supply?
Kindest regards,
Lucas.
Doede
Hi Doede,
I choose active conversion because it has more bass and more dynamic sound.
Listening test conditions???
I live a while with the mod and if I like it I keep it in.:idea:
If I don't like it it goes out. :smash:
Lucas,
when you’re not using the regulation on the DDDAC board, you should only solder in the BG caps. AFAIK you would have to increase the voltage of the external supplies to feed the regulators on the DDDAC board. If this would result in better performance? I don’t know… Maybe then you could just as well go with Doede’s original Accu supply.
My trafos are 12V AC (16VA) for the 8.5V regulation and 8V AC (8VA) for the 5V reg. I think that’s adequate.
Hi Bartek
I don’t have a full scheme of this DAC. I just made sketches from the single boards. I will upload some of them during the next days. So check the link in the first post from time to time.
But here are already several full schematitcs available.
This DAC is based on:
http://home.student.utwente.nl/f.s.bouwman/audio/images/nonoz-schematic.gif
http://www.dddac.de/files/dddac1543ver22.pdf
Elso’s Reclocker
Highly filtered and regulated power supplies.
Yes, it’s the PS suggested by Elso.
Fabian
