Hi everybody,
Look at this project:
http://sound.westhost.com/project85.htm
Perfect!
Finaly a DAC project everone could build! This project so simple that a PCB is not needed..
It is gonna be my first DAC project (only used a evaluation board before, which is no fun)..
any suggestions, advice, comments..
I tried all night to find and order the parts be could not find them... what should I do now?
I would like to build it simultaniusly with a some DIY'ers.... 3 or 4 weekends should be enough.. we could share info through this forum...
greetings,
Thijs
Perfect!
greetings,
Thijs
I was thinking of doing that project except maybe substituting the CS4334 with a Burr-Brown PCM-1728 and using an opamp output stage. The only thing is that the CS8414 is virtually impossible for me to find... If I could find the CS8414 and the CS4334 I'd use them but I know of no place that sells them. That's why I got myself the PCM-1728. I was thinking of using the DIR1701 as the receiver but it's not as simple and straight forward as the CS8414 (I can't find any as easy as the CS part unfortunately). And I was planning on using some LM7171's (I like them alot) on the output stage (this would also be very easy, and wouldn't complicate the whole project).
You might want to consider using alternative parts as well, cirrus doesn't seem to offer free samples of these parts, and I can't find any place that sells them in bulk, forget about single quantities then...
Thanks for the reply,
still haven't found a source for the parts yet .. been looking on the net all day... which cost more than the parts them self on phone bills :-(
since I have a opamp output filter type of DAC already .. I wanted to go for a single pole output filter desing with a zero offset, cap-less 2n5457 N-fet output buffer which I found on the net ... like is shown on the "tape output buffer for ZEN preamp" post...
I would be very happy to know how you project is going... is the Burr-Brown PCM-1728 easy to implement.. BurrB has a good reputaion on DAC's maybe I will go the same way..
goodluck,
thijs
goodluck,
thijs
Well the PCM1728 is pretty simmilar to the PCM1716 and http://digilander.iol.it/paeng/a_simple_96kHz_DAC.htm has a DAC using it. It's pretty simmilar in use to the CS4334.
As for my project so far, I've just been accumulating parts and working on the output stage and power suply. Haven't found an easy to use replacement for the CS8414 yet, or a place to purchase it if I can't find a sutable replacement.
The AD1892 :
1. need a good oscillator like the ones from www.lcaudio.dk (24.576MHz).
2. it does not convert more than 20 bit signal .. Soo DVD??
3. The output samplerate @ 24.576MHz is 48KHz
4. The output samplerate @ 22.5792MHz is 44.100KHz
5. The output word size is 16 bit or 20 bit.
6. It does eat signal "directly" where the DIR1701 needs a RS422 receiver wich can operate at more than 13MHz (96Khz*32bit data* 2channels? There is missing something inthis calculation ... Ohh yes biphase .. "1" are shown as the double frequency of "0" => 12.288MHz)
I hope it helps
Sonny
I hope it helps
Sonny
Well, it seems like it'll do most of what I need, except it bothers me that it'll only do up to 20bit signals...
But I was thinking of using the AD1892 and the AD1852 (instead of the PCM-1728 as I had originally planned). I'll still use the LM7171s on the output though.
Although I won't use it for DVD, I'll use it for CD and PC soundcard output. So if the soundcard isn't 24bit output (SB Live) it'll do fine, so I'll have to check that (I hope it's not 24bit)...
It took me about 30 s to find this:
http://www.sc-elec.demon.co.uk/cs8414.htm
and
http://www.sc-elec.demon.co.uk/cs4330.htm
Never heard of the good old altavista?
Another solution might be to go for the previous models
cs8412 and CS4331 which are available and cheap.
and
Couldn't help but reply... glad to see interest in the "simplest DAC ever" =)
I have several extra sets of Crystal chips (4334 and 8414) leftover from my DIY project contributed as project 85 on the ESP website. If there are enough people who want them, I could purchase them in great enough quantity lower the price -- the 8414 is a damn expensive chip!!
You have to have your SPDIF signal present at power up? I see no provision for resetting the CS8414 on your schematic... usually the 8414 won't even start decoding until it is reset (even at power up) by bringing M0-M3 high.
JoeBob said:Well the PCM1728 is pretty simmilar to the PCM1716 and http://digilander.iol.it/paeng/a_simple_96kHz_DAC.htm has a DAC using it. It's pretty simmilar in use to the CS4334.
I'd go for a CS8414 (and maybe a CS4334 as well) as long as the price is right. By damned expensive, is that $50, $20 or what?
But seriously, that'd be a really nice thing to do. Otherwise I'd have to use an AD1892 and only have 20bit (and it still wouldn't be as simple as the simplest DAC ever...).
EDIT: that's wasn't my schematic, just one I found. And yes I noticed that there wasn't a circuit for resetting it. But I'd obviously add it.
Here in Sweden, the 8414 is available at http://www.elfa.se/elfa/produkter/se/20/2021965.htm (ELFA) for about 160:- SEK ($16) + vat. Though foreign people don't pay swedish vat, it could be good for you to know it's about 25% for us poor fellows that has to pay it.
Regards,
//magnus
Regards,
//magnus
Hi there,
Don't know if it could be of any interest, but our US (and perhaps Canadian) friends can order the CS8414 from Nuhorizons for $10.09 (www.nuhorizons.com) - Min order of $25 for grand total. I did it a long time ago and haven't had any problem.
Hi JoeBob,
No, sorry, didn't try to get samples from them. Just ordered the whole 96 kHz Crystal bunch (8414,8420,8404) in the regular way
Guess you would have to meet some requirements (e.g. be a company...) in order (What a pun !!!) to get samples, but may be it's worth a try ![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
- Digital Source
- DAC, project 85 of Rod Elliott
