http://ctlgserv.mew.co.jp/ctlg/acg/...eric__BookTextView/121783;td=2;cs=dynaweb1.wv
here they are. Strange however that they state 4Amp the boxes clearly state 5A
/ Micke
/ Micke
I still have lots and lots of these.
There is a datasheet availble from RSonline if you follow this link.
http://www.rsonline.se/cgi-bin/bv/rswww/searchBrowseAction.do?N=0&Ntk=I18NAll&Ntt=127-9279
Mikael,
i've just received the relays, even the wrapping paper looked like a birthday present.
Repent, Sinners =>
Buy the most affordable ticket to audio paradise.
You can't get a better power relay, you can't get it cheaper, not anywhere.
http://images.mercateo.com/pdf/Farnell/19027.pdf
Repent, Sinners =>
Got a whole bunch of them here (500+) these are 5V relays with very good specs,
/ Micke
Do you still have some of those relais left? I would need 10 pcs.
