Joined 2002
JasonL said:I think it is time for a new keyboard man. : O )
![nod :nod: :nod:](https://files.diyaudio.com/forums/images/smilies/nod.gif)
Anyways how much does it cost to have a PCB made like that? Also how do you find places that do that?
Good job though, it looks very nice.
mdlover said:Thanks all!
Andrea,
Yes, I draw the PCB using CAD and send to the board house.
The sound is good, rich bass and musical. I think it will improve after burn-in.![]()
Bricolo,
The configuration of the TL431 is just the usual way.![]()
I will prepare the sch. and post it here.
Cheers
Hi mdlover
Do you have the schematic?
Alex
banana said:Hello mdlover!
Where did you got your PCB fabricated? For how much? Do they made double side PCB??
Thanks in advance.
Hi Banana,
you can have those PCB manufacturer ads. in local electronics magazine.
i think they have no problems in making double sided board and cost will depend on your board size, quantity.. etc
hope this helps
cheers
And I've got no problems with the same board. I use standard resistors but Multicap PPMX for output. So far it seems pretty good. Now playing with the Elektor OPA627 pre and my GCs on a pair of home made speakers. The DAC soon goes into a Conrad case same as for the GCs.
Thanks a lot mdlover for the boards and TDA1543.
- Digital Source
- My 16-bit 1543 Non-Os DAC
