You're all wet.....
think you are confusing dampening with damping. You better go look up the dielectric constant of water while your at it. I gave about two days worth of references on damping materials, and you want to use fluid........ And you wonder why people think you have some goofy ideas and question your observations. I guess it is novel gimmick like the shoes with goldfish swimming in the heels.
Yes, parts sound different. Most of the serious tweakers have know it for 10 or 15 years and many people are even aware of why they sound different in terms of things that can be measured or conceptualized with models. Good parts are secondary to good design and I think power supply design is what was under discussion.
Whoops snuck in under the advisery from PD
Thanks, Millwood.
That confirms my fear...guess I'll need to rob one first then.
Sorry for the OT.
I agree, yet there is little use for great circuit design if the PSU isn't up to the same standard either.
Anyway you look at it it's all tightly related...
After all a preamp or amp is nothing more than a power supply modulated by the audio signal.
Cheers,😉
it would be hard pressed to find any investor in my business (private equipty) who would invest in high-end audio tho. Ripplewood owns D&M (Denon and Marantz) and they are one of the better investors in distressed situations - and the fact that they are involved with a pretty healthy name like Denon should shade some light on how the whole high-end audio segment (and consumer electronics in general) is perceived by the financial community.
Thanks, Millwood.
Sorry for the OT.
Cheers,😉
Re: You're all wet.....
You talk about damping, they talk about dampening. I guess thay can be excused, as they are French😉 Taken from the add in a famous audio mag. Whoops, snuck in under my advisery also😉
Fred Dieckmann said:think you are confusing dampening with damping.
Damnppphhh...
I wonder where they put that goldfish... 😉
You talk about damping, they talk about dampening. I guess thay can be excused, as they are French. Taken from the add in a famous audio mag.
Re: Damnppphhh...
There are two bowls in the picture....
fdegrove said:Hi,
Geeez...and I just thought those were Big Brothers' eyeballs.😉
Honestly, as much as I like Cabasse speakers, I wouldn't want a set of those eyes in my living-room...
Cheers,😉
Cheers,😉
Frankly Scarlett I don't give a damp.....
http://www.wsu.edu:8080/~brians/errors/damped.htm
Actually I see the term corrupted as dampened pretty often now. I guess it is no more annoying than teenage girls using you know... and like.... as verbal punctuation every 5 words. I once counted the "like"s in the conversation at the next table while eating but my wife made me stop when I got to 50. So like if you want to write like "dampen" you know.... like whatever...... you know.
RE:Frankly Scarlett I don't give a damp.....
Unfortunately there's a damnped error in the above link.
I don't like that.
I would like to use the correct word...I don't like the damp look in Scarlets' eyes either.
Frankly,I liked the movie, though...😉
I don't like that.
That's odd...... what the L?
http://www.wsu.edu:8080/~brians/errors/damped.html
When the vibration of a wheel is reduced it is damped, but when you drive through a puddle your tire is dampened. "Dampened" always has to do with wetting, if only metaphorically: "The announcement that Bob's parents were staying home after all dampened the spirits of the party-goers." The parents are being a wet blanket.
Re: That's odd...... what the L?
is that right? I always thought that to damp is to moisture, and to dampen means to reduce vibration. so in this case, to dampen one's spirits actually means to reduce one's spirits, literally.
Fred Dieckmann said:http://www.wsu.edu:8080/~brians/errors/damped.html
Acc to Oxford Dictionary,
Damp: slightly wet
Dampen: to make sth slightly wet
Ah... Ha!
Dampening the sound is to make the sound muddy and sticky...
Damp: slightly wet
Ah... Ha!
Damn dampers damped better when dampend, damnit.
Damn dampers damped better when dampend, damnit. Post #12
It was once common practice in recording studios located in arid climates to spray a mist of water about the studio space in order to create a higher and more constant humidity.
Raising the humidity would increase the density of the air...
Effectively the sound would be dampened and yet simultaneously brighter.
Such a paradox.
Ironically, my brother-in-law built a lab at WSU while working as a professor of civil engineering to study the effects of viscous dampers for reducing damage to architectural structures caused by seismically induced motion (or something like that). His dampers had been dampened with a viscous fluid so that the earthquake motion could be damped.
Such a paradox.
Damper dampening..hmmm...if I damper something I make a restrictive load...and If I dampen something I create some sort of viscous coupling to separate from the load.
ex..dampers...to restrict air flow
ex..dampening...sinovial fluid in the bursa sack that creates a cushion for knee cartilage......moter mounts.....viscous couplings between drive units..LOL
Damp on MacFred!
Damp on MacFred, and dampen he who says enough!
Warning.... pun on possibly obscure cultural reference
Out, damped spot! out, I say!
- General Interest
- Everything Else
- Somebody damped that discussion over here
