I bought a few Tripath 2020 amp modules recently, as spares and repairs.
I was wondering what this amp module is and where I can get more info on it?
It seems to have a built in pre-amp and speaker protection which is pretty nice.
Pics:
Excuse the quality pf thepics, they were taken with my phone...
It appears to be branded "Hi-fi Audio"
and also says "Version:2.5a" on the PCB...
Also, when I plug power up to it the red "OVER" LED light up straight away... I have yet to hook it up to any speakers however...
Pics:
Why not ask the person who sold it to you (I presume it came from "gatesof")?
At a guess, it looks like it perhaps originated from eBay seller "I wanne Buy" [sic], who presently appears to offer a similar "Hi-fi Audio" branded TA2020 board, "New Ver PCB 25watt CLass-T amplifier for Tripath TA2020", sans speaker protection and 2 LEDs:
http://cgi.ebay.co.uk/New-Ver-PCB-25watt-CLass-T-amplifier-for-Tripath-TA2020_W0QQitemZ330330959984
Personally, if you haven't already done so, I'd concentrate on fixing the Charlize!
Robert_S
Robert_S
ebay, as spares or repair (non working)col said:Where did you get that one from?
col.
It was gatesof, I've sent a message but have yet to hear back from him/her, hopefully they should remember.Robert_S said:Why not ask the person who sold it to you (I presume it came from "gatesof")?
Cheers, that does look very similar, I've been doing quite a bit of searching for various TA2020 modules and that's the closest one I've seen so far. I'll ask them if they have any more info on these modules...Robert_S said:At a guess, it looks like it perhaps originated from eBay seller "I wanne Buy" [sic], who presently appears to offer a similar "Hi-fi Audio" branded TA2020 board, "New Ver PCB 25watt CLass-T amplifier for Tripath TA2020", sans speaker protection and 2 LEDs:
Well, I've been pretty busy this weekend, but it looks to me like it might just be some lifted PCB tracks around one of the speaker outputs so should be a pretty simple fix. 😎Robert_S said:Personally, if you haven't already done so, I'd concentrate on fixing the Charlize!
I'm sure the Charlize is the best sounding of all the TA2020 implementations but it is quite costly in comparison to the "Iwannabuy" version. Iv'e ordered one and will compare to my modded Lepai.
col.
col.
Iv'e received my "iwannabuy" TA2020 board. It's a bit different to the one in your pictures Mike. It sounds very good though. Will bed it in a bit and use it to power my compression drivers/waveguides in the high section of my home HiFi.
report back soon.
col.
report back soon.
col.
col said:Iv'e received my "iwannabuy" TA2020 board. It's a bit different to the one in your pictures Mike. It sounds very good though. Will bed it in a bit and use it to power my compression drivers/waveguides in the high section of my home HiFi.
report back soon.
col.
Nice, I still haven't got my module working yet, I'm glad to hear it sounds good.
I'm still playing with my lapei right now, but as soon as I get this module going I'll let you know how it compares to the Charleze 🙂
report back soon.
col.
will it be possible to put up the picture of the unit if it produces "good" sound?
thanks,
gychang
I'm currently building a case for this. Once Iv'e finished I will present photos. It is a nicely implemented module with good components.
cheers,
col.
cheers,
col.
HiFi Audio version 2.0A by Lu.RH TA2020
Iv'e finished my "iwannabuy" TA2020.
Some photos here:
http://pix.minirig.org.au/main.php?g2_itemId=1081
Sounds very nice.
Iv'e utilized an old 3.5" hard disk enclosure and bracketed the laptop power supply into the case. Used a LM388T regulator circuit to get the voltage to 13.5v
col.
Some photos here:
Sounds very nice.
col.
Re: HiFi Audio version 2.0A by Lu.RH TA2020
The pictures look very nice.
do u have any other t-amp clone to compare the sound to?, was any mods done?, it has the volume pot already built in?
thanks,
gychang
Some photos here:
Sounds very nice.
col.
thanks,
gychang
I have my Lepai,TA2020, that has been extensively modded though, It sounds very similar. Also, I'm using this one to power the highs in a tri-amp system, so there is no bass going through it at the moment.
The board design is very nice, almost identical to the TA2020 evaluation board spec but with the later developments.
col.
col.
col said:I have my Lepai,TA2020, that has been extensively modded though, It sounds very similar. Also, I'm using this one to power the highs in a tri-amp system, so there is no bass going through it at the moment.
col.
thanks for info, it already has heat sink, volume pot?, looks like ready to go, will assume bass will be adequate.
will try one.
thanks,
gychang
MikeHunt79 said:I bought a few Tripath 2020 amp modules recently, as spares and repairs.
Pics:
Mike, did u by any chance have comments on the sound?
thanks,
gychang
Re: Re: What amp module is this?
I've been really busy lately, but if it's sunny tomorrow and I have some spare time, I'll have a go at fixing it. 🙂
I still haven't got around to fixing mine, it just shows a fault LED, I think the TA2020 may have gone tho I'm not sure yet, it could be the diodes also.gychang said:
thanks,
gychang
- Class D
- What amp module is this?
