So, I'm trying to gauge interest in this. I discovered this product from EUVL (Patrick) in the following thread:
http://www.diyaudio.com/forums/showthread.php?threadid=37262&perpage=25&pagenumber=1
I ordered a sample piece and cut it myself and got very good results. Patrick also posts some results in the above thread.
The specific product I'm interested in doing a group buy on is the new Keratherm Red 86/83, which performs even better. Datasheet is here:
http://kerafol.de/jml/pdfdocs/thermalmanagement/db/eng/Keratherm_rot_eng.pdf
I've contacted the US distributor and the MOQ is 1000. I've selected two precut sizes that I think will work quite well. The A and B dimensions are length and width, and the C dimension is the distance from the top to the center of the mounting hole, and D is the diameter of the hole. The dimensions in millimeters are as follows:
TO-220:
A: 18,0
B: 12,0
C: 4,5
D: 3,0
TO-247:
A: 32,0
B: 23,0
C: 7,0
D: 3,0
Both pads are 0.25mm thick.
At the moment, the cost for the TO-220 is $0.25 each and TO-247 is $0.76 each in MOQ of 1000. Shipping from me to you should be very cheap, as these can fit in a envelope with minimal weight piece of cardboard added for rigidity.
I personally have a use for ~600 of the TO-220 isolators, so there is no doubt in my mind that we can go forward with that part of the GB. My use for the TO-247 size is smaller, but I'm guessing that's what most people around here want.
Notice the pricing is around half that of the highest performing Bergquist isolators available at Digikey at a significant bump in performance. I'll leave it to you to decide if it is worth it for your application.
Anyways, my feelings won't get hurt if this GB doesn't get off the ground 🙂 At this point in time, nothing is official, just trying to get an idea of the interest. Most likely I will have a minimum order size, but it's too early to state what that will be. In the past it's always been around $25, but I may lower that for this particular GB.
Thanks guys!
-Marc
TO-220:
A: 18,0
B: 12,0
C: 4,5
D: 3,0
TO-247:
A: 32,0
B: 23,0
C: 7,0
D: 3,0
Thanks guys!
-Marc
Hi Marc,
600? Going pro, eh? 😉
Maybe you want to consider buying a few sheets in addition to the precuts, there are a number of nice parts out there that do not use standard packages, like the 2SK1530.
Have fun, Hannes
Have fun, Hannes
h_a said:Maybe you want to consider buying a few sheets in addition to the precuts, there are a number of nice parts out there that do not use standard packages, like the 2SK1530.
Cutting the sheets is an experience I don't really want to do again 🙂 Getting the hole exactly the right size with no shearing was kinda tricky... well, that and finding metric sized hole punches. It's hard to "aim" the hole punch, as many do not have a way to center the punch on a marked dot, for example. I just was concerned about the long term stability of this process.
I'm interested in 48 of the T0-220 size; and, 16 of the TO-247 size. Thanks for doing this; and, I hope it gets going really strong.
I'd like 20 TO-247 and 30 of the TO-220. I am going to have to do some trimming to get these to work for an LM3886....
I am watching this with amazement.
The original post was in Oct 2006, and no one else other than Jacco had paid much attention. Hats off to Marc !!
Patrick
Patrick
32mm x 23mm is enormous for a To247.
It will easily fit a To264. More than 2mm spare around every edge.
AndrewT said:32mm x 23mm is enormous for a To247.
Yes, perhaps your correct. I was erroneously calling the 2SJ201 a TO-247, which I see is not correct. Is it a TO-3P? In which case (
So, I guess Hannes, it will fit 2SK1530 🙂
Andrew, are you recommending that we look at a smaller size?
I like the bigger size -- more flexibility: you can shave down but not add width. And it doesn't hurt anything.
With 2mm (0.08") overhang on each, you only need to mount transistors 4mm or a hair under 3/16" spacing between the transistors to avoid overlap.
Just my
Just my
HaLo6 said:LM3886 are 20x17 (WxH) ... are these pretty easy to trim?
yup, indeed they are. Don't forget about verifying the hole location and diameter though.
I'm glad to hear that as I didn't bother to look at the dimensions.
Better don't rely on that in general, you know there exist people that order TO-247 Silpad heatpads and jeez they don't fit a 2SK1530. 😀
But the same people coudn't be held back to change the design in the last minute as initially other fets (real TO-247) were planned 😀
So what - the perfect excuse to order some sheets of Kerafol
Have fun, Hannes
Originally posted by h_a I'm glad to hear that as I didn't bother to look at the dimensions.
well, probably that was my doing as I recently bought 50 pairs of 2SJ201 / 2SK1530 at the price of $(highway robbery / 2) and subconsciously knew I'd need fancy pads for them 🙂
Nice choice 😀
Oh also thanks to Patrick for sharing his gadget! I've never heard of that company before.
Have fun, Hannes
Have fun, Hannes
I have posted a lot more gadgets than people have ever noticed or paid attention to.
You just need to search under EUVL, dig them all out and read all over again ......
Patrick
Patrick
- Group Buys
- GB: Kerafol Keratherm Red Isolators (TO-220 / TO-247)
