I get conflicting Info on the net of this panel, Just wonderedif any of you know the Definate answer thanks again. Edit the 210 not the 250
acording to rolms chart, it is vga... hey... i just picked up a z210 for $36 on ebay 🙂 !
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=2724608348
really Cool deal, yea I found one locally but if Its only 640X480 Im gonna pass on it they wanted 100.00, Good deal Hopefully that panel works for you, Did you get your Z115 working?
Who is selling that for $100... Yea i got my z115 working. The thing is awsome! You can read more in the good deal/bad deal thread.
do you know the difference between a z110 and z115? Is it the composite video connections only? I did a search but no one explicity determined the difference.
TIA
TIA
Sorry, this post is a little late 🙁, but i figure it may help someone. I just got an nview z series manual. What is says, is that the difference between the z110 and the z115 is only a composite/s-video add on card. The z110 can be upgraded with the option (though nview is out of business, if one were to come across a z115 with a dead lcd and had a z110, they could put the video card add on from the z115 in the z110 🙂. The same is with the nview z210 Vs. the z215. What is the difference between the z11X an and the z21X panels? the z11X is 1.2 million colors, while the z21X is 16.7 million colors. Both panels are VGA (640x480) resolution. If anyone needs the manual, I would be glad to scan it 🙂. Hell, I even have an unfilled out nview registration card 😀. On another note, these panels use regular barral style power jacks that are 12 volts 2.9 amps (and the inside of the jack is positive). The Z3XX panels use a different type of power jack that is hard to come by, so if you see a z3XX series panel with no power cord, and your not savy with a volt meter and soldering iron, do not buy it 🙂.
