I found these on Digg...
http://www.noiseaddicts.com/2009/04/plasma-speakers/
Here's a link to enjoy the music's review
http://www.enjoythemusic.com/magazine/equipment/1002/acapellavoilin.htm
The famous Ionovac tweeter has its own website, which gives very good information and resources:
http://www.ionovac.com/
It does indeed.
This looks more like a modulated stun gun. Or a mixture between a class D amp and a flyback converter. It uses a ground electrode. The plasma flame creates a corona by using a high intensity RF carrier, which doesn't use a ground electrode.
I'd like to build something like this. The design could probably be much improved. The 494 most likley isn't the best device for modulation. I'd take a look at some full range class-D modulation chips/topologies . Or, perhaps chips meant to drive flyback converters. Also, that output stage could benifit from a DRC snubber. I bet it has some voltage kick back issues as-is.
