i have found in a box that i had forgotten about a brand new Crimson preamp pcb, this was sold as a kit as is ready assembled, it comes with original paperwork (this is a used copy of paperwork but original).
Note the following NOT SUPPLIED
requires usual +/- 15Volt psu
Volume pot
Balance pot
Input selector switch
has MM disc stage on board
these were well respected in the day, i built a few of them for different people.
i am open to offers on this one. please ask for more information
Volume pot
Balance pot
hi guys
i was incorrect with the sizes, they are135X80X23mm
i have now tested this board and is 100% working
open to offers this must be some use to some one as a first project, it
requires
volume pot
balance pot
input selector switch
power supply -15 0 +15 @ 25 mA
and a box to put it in
come on you wont insult me, i just think it is far to good to throw away.
requires
volume pot
balance pot
Spec
spec preamp
output voltage 0dbm (0.775mV) will drive 99% of poweramps
output impeadance 600R
input sensitivity -20dbm (70mV) line in (adjustable)
input impeadance 560kR
power requirments +-15 volts @15mA
spec moving magnet phono stage
2.0 mV suits most magnetic or high output moving coil cartridges
47k @20pf adjustable to suit cartridge used
RIAA accurate to better than 1 %
go on its a good project,
these amps were loved at the time knocking the pants off stuff costing 20 times more, you might get it for a few quid
spec preamp
I have published some info on this PCB here
http://homepage.ntlworld.com/bepowell/schematics/CPR1b.pdf
I hope this proves useful
Brian Powell
designer for Crimson
Brian Powell
The PCB is called a CPR1 and here is a link to the schematic and update info.
http://homepage.ntlworld.com/bepowell/schematics/CPR1+parts+update_exch.pdf
