learning hornresp with staiper design
Greets!
This is a tapped horn (both sides of the driver is loaded) and the various HornResp input parameters are conveniently already listed, so it's just a matter of choosing a conical TH calculation per the HELP instructions and inputting the driver specs, S1-S5 horn segment areas and L12-L45 (noted as 'c') axial length specs listed. This assumes that the driver's bulk (Vd) has already been subtracted from S4.
GM
