Hello,
I have recently moved house and am trying to clear out alot of stuff I don't need or are unlikely to use. These are NOS mullards. Military versions I believe and there in the boxes. They have not been used. I originally got 4 of them to make a full wave rectifier after seeing a schematic for an Audionote Ongaku amp! 🙂. I heard rave reviews about it and I was still a novice with electronics. The OPT is the key part plus the caps and construction. (how naive I was at the time!).
So yeah they could be used for SE Triode amps 211, 845 etc with large HT rails.
Anyway here is a link I come across yesterday.
http://www.mullardtubes.com/MullardRectifierTubes.aspx
To quote from the above website - "Without a doubt the finest GZ-37 available today only exceeded by the High Wycombe CV378 "Fat Glass"
I took these pictures about an hour ago.
limono said:and the price is??
Having a good look around I am looking for £180 for the four ie. $265.00. This is pretty cheap if you look at some other sites.
http://www.mullardtubes.com/Mullard-GZ-37-GZ37-CV378/?ID=0&ProductID=150
nearly $150 a tube or this one
https://www.tubeworld.com/gz37.htm
Between $100-$150 per tube. That site has some good information on it regarding the valve. I don't know enough about getters etc.
Lastly I forgot to mention that all four tubes have the same date codes YE. Mid 60's I think. As you can see from that link just above, the internal construction has changed over time. So it's a mix and match affair.
PS. Ignore delivery costs. I have stuff (palettes) going to virginia at work all the time and it will be well packed.
Best Regards
Kevin
I may knock the cost down to $200 for the Quad. And cheap delivery to USA.
Just sent you one back! Literally about about a minute ago! 🙂
Unless it's a new one
I will take paypal.
Kevin
I will take paypal.
Kevin
Just thought that I should follow up on this. I spoke with Kevin and we worked out a deal on the GZ37 rectifiers.
I received them last week and everything is looking great. I'm pretty excited to use these in my 300b project.
Thanks much Kevin!
Thanks much Kevin!
CV378's
Hi Doug, new here but been around the Asylum, Audiocircles and Audiogon for a long time. If you have any interest in selling a pair of the Mullard's, shoot me an email.
thanks,
Randy
thanks,
Randy
doucanoe said:Just thought that I should follow up on this. I spoke with Kevin and we worked out a deal on the GZ37 rectifiers.
Thanks much Kevin!
How's the 300B amps going? . Starting myself on some solid state types with jfets etc for bi amping. Recently bought some good speakers so going to bi amp them etc.
Let us know
All the best
Kevin
Hey Kevin,
I have been somewhat sidetracked by a couple a speaker projects I was working on and the 300B project was put on hold. I have most everything I need now however and should be back at it soon.
The 2A3 amps I bought to keep me occupied in the interim have been my downfall. They reduced the urgency to get them done quite a bit 😀
I will keep you posted when they get full attention again.
RC
RC
