italian style
The first circuit is simply Musical Fidelity's A1 power amplifier redrawn, without component values.
The "Chet Baker" Amp is a Rotel clone with a slightly different output stage - the graphics used for the schematic, style of compensation, plus the choice of transistors is identical to many Rotel service manuals.
The Chet Baker schematic has a Bryston style output, which can be tricky to keep stable.
One thing the 0.22 resistors in the collectors of the CFP output devices serve no purpose. I think they should be moved to the emitter side.
I'm interested to hear if it works
In the original project could not a good result
modified some parts in the scheme to operate the simulator see the components changed:
R103 and R113 = 47k
R115 connecting a capacitor of 220uf to the ground.
R127 = 2k
Vr103 = 1k
R125 = 1k
q107 put capacitor 22pf of B / C.
Stee the simulator seemed ok but I want good opinion of other friends of the forum here because the simulation was done with some changes and to make sure the quality of the amplifier will have to mount the project.
simulation found in the high THD.
R20 and R21 in the emitter because the problems in the simulation showed bias when in ultilizado collector.
may be some bug in the simulator and not 100%.
Mounting the project in practice show the reality of the project
