NEC Proto Type 5 inch Screen
Some one is selling this on eBay. Looks interesting. But no additional information.
link
idea
do you think this would work well for just movies with a 150w metal hallide lamp?whould it be easy to put the controler together that erthlcd has and you said it could wotk with?
Just an idea,if it can work i would like to make one.
Yes. Do you see the connector? That's the same one Earth uses. It's a Centronics 44 pin. Earth will sell you a custom cable that has the same connectors as that one, but is wired up so the pinouts of the panel match the pinouts of their LCD controller. If they don't have that panel on file, just email them the pdf and your set.
The nice thing about that is that you don't need to have some cable flapping around. There's a nice plexi enclosure that will house that connector perfectly.
BTW, Earth will sell you a PC connection kit for ANY TTL panel (XGA or lower only), provided that you can supply them w/ the pinouts if they don't already have it.
Most newer laptop panels are higher than XGA, and have LVDS recievers built in, making Earth useless when it comes to connecting those up to a PC. But for this 5" thing, they're perfect. Just gotta be willing to fork out the dough.
