Hi, i find this schematics.
This works?
How many watts? In Class A or AB?
Someone to build?
Sorry, but I speak a little english
This works?
Someone to build?
Hi Havenwood
This N-FET output circuit is used YAMAHA B-1 (but it was not MOS ,"SIT (V-FET)",before.
Recentry this is used KANEDA type amp (by UHC-MOS)
EX.( It was seem to be from 2004.12 "MJ" magagine)
http://www002.upp.so-net.ne.jp/VivaMari/audio_life/UHC_MOS_Amp.html
I have not made this type amp ,so I don't say many,sorry.
only info.
REGARD
only info.
REGARD
It is Quasi's NMOS 200 amp, his website is here:
http://www.adam.com.au/cgpap/QuasiWeb/index.htm
It has been built by a few forum members who report it works very well. It is a class AB able to deliver around 100W into 8 ohms.
Hi, thanks!!!
This is the amplifier
The Class A Amplifier is very interesting.
http://www.adam.com.au/cgpap/QuasiWeb/pdf's/N30-classA.pdf
Also is an excellent site
I will soon begin to build it.
Thank you very much again
if Quasi should change the name of his PDF folder
from /pdf's/
to /pdf/
then his links would not be broken when posted in forum.
Forum software does not like single quotes in posted links: [ ' ]
Single quotes have special issues in PHP+MySQL Database scripts.
This would of course work just fine:
from /pdf's/
to /pdf/
Code:
http://www.adam.com.au/cgpap/QuasiWeb/pdf/N30-classA.pdf
unfortunately this link is death. do you know the currently link?turnA_zpoint said:Hi Havenwood
only info.
REGARD
thank you very much for finding out.
additional the link from the follow comment
also is death.
Both links are working for me, the first directly and the second after about ten seconds of own efforts (strip last dir in path, then follow the redirection) 😉
hi there
here is the site link
http://users.adam.com.au/cgpap/QuasiWeb/index.htm
ravs
be a vegeteriaan
ravs
be a vegeteriaan
more NMOS versions
I have start a new thread regarded this:
"Only N-Channel MOSFETs (NMOS); better Audio from non complements by Audio Power?" please go to
http://www.diyaudio.com/forums/showthread.php?s=&threadid=148646
- NMOS Amplifier
