Antique Electronics Supply has been running a "25% off sale" on many NOS vacuum tubes for the summer. They recently added a list of tubes priced at 50% off. I went through the entire list looking for tubes that interested me, and found a few real bargains. The list does contain plenty of tubes that just won't work for audio, or some that I already have too many of, and some that I can buy elsewhere for less even at 50% off. Here is the short list that I ordered and why:
6AQ4 for $5.70. SY and others have proclaimed this a great tube but I have never seen them below $12 each, therefore I have never tried it.
6MF8 for $1.65. Another tube that I have never seen but it looks like an excellent canidate for a spud amp.
6DG6 for $1.70. This is another name for a 6W6. These are capable of operating well below 100 volts, thus can be used for hybrid "super tube" and low voltage amp experiments.
12L6 for $1.13. This is one of Wavebourne's favorites. It will also work well below 100 volts (maybe better than the 6DG6). For $1.13 I can do some "testing" without worrying about blowing up something expensive. They are limiting customers to a maximum of 8 on this tube.
6CB5A for $2.00! I remember this one from my days as a TV repair tech. It was one of the strongest sweep tubes available in the 1950's. It is no 6LW6 but for $2 who cares. Expect some serious testing on these!
Curves look good for a P-P output tube. Screen drive curves look good too.
Man I hate when you do that, this is going to be expensive.
Yeah, I know. I started out looking at this list. I looked up each and every number. Then I called the Tube Center to check prices. Then I bought some tubes for experiments from each place. That cost me about $300.
Some tubes are going into projects that I already have planned. Most are for "science." There will be more photos of glowing tubes in the near future.
I bought some surplus Plitron 400 watt toroidal P-P OPT's on impulse last year. How many of those 6CB5's do I need to wire in parallel to wake those things up? At $2 each I can afford to find out.
I better add these into my cart and commit 🙂 Thanks for the heads up, George!!
If you are getting any of these for your own experimentation, go for it. Don't buy them based on my purchases. The only thing that I can guarantee is some glowing tubes, and some smoke! Many of my "educated guesses" don't work out. I have no problem trying experiments with $2 (or less) tubes that I would never try with expensive stuff. I may even sacrifice a pair to find the limits, although the 6BQ6GA's that have been seen glowing like light bulbs are still alive! The $0.98 6BQ6GTB's from AES are not the same and will not take that sort of abuse. I have verified this! I have some more 6BQ6's coming from a different source that will be tested.
My long term plan is to develop a "universal P-P driver board" that can drive anything from a bunch of sweep tubes in parallel, to a pair of 845's, to the usual pair of 6L6GC's - 6550's - EL34's. Screen driven applications will be supported too. Now you know why I have been collecting different sweep tubes with different drive requirements.
Don't forget the dollar sale at RES: http://vacuumtubes.net/
I picked up some 6LU8's and 6JW8's for $1 based on some of your posts.
6AQ4 for $5.70.
Buy. Damn, this is a bad time to be out of money.😀
I can't claim credit for this one, I was turned on to it by Greg the Geek and Erik deBest. It runs surprisingly well at lower currents (1-2mA) with CCS plate loading.
Didn't know about this one. It only cost me $50.
Wow, some fascinating tubes there. That 6CB5A looks really nice. A slightly derated 6LQ6 in octal socket for 1/30th the price... what is not to love?
I also note that they have the 6BQ7 for $1.55. Wouldn't that one make a nice general purpose preamp tube for voltage amps and as CFs? How do they perform in the noise and microphonics department?
Man I never have the money to take advantage of this stuff. 😡
I have used that one for an LTP phase splitter. It works good for that service. I can't speak for the noise and microphonics performance since I used it at a relatively high signal level. Some TV tuner tubes are purposely designed to have a semi variable Mu. This can cause excessive 2nd harmonic distortion in SE use. The 6ES8 is an example. I did not notice this effect with the 6BQ7. I did not test its cousins the 6BK7 and the 6BZ7 yet.
The 6CB5A is a much older design than the 6LQ6. I first spotted this one in an Emerson color TV from about 1956. I rebuilt the TV in 1968. It was rescued from the trash and was the only color TV in our neighboorhood at the time. There were about 20 people in my room during the lunar mission that was televised in color. Note the difference in specs from the Sylvania and other data sheets. I haven't seen one of these tubes since that TV, but I will soon be "testing" some.
12L6 is pretty well identical to a 6W6 (12W6) from memory. Datasheet lists some slightly different ratings.. but look at the curves.
Man I have already spent about 270 on tube this week, If I do any more my fiancee will kill me LOL.
How long is this sale for?
I actually got a 6BQ6GA in a lot of tubes of the bay awhile ago, I could use a few more Too.
Nick
Nick
Colt45 said:12L6 is pretty well identical to a 6W6 (12W6) from memory. Datasheet lists some slightly different ratings.. but look at the curves.
Yep.
I bought a few of the GE 6DG6GT/6W6 with the wafer base, and a half dozen 7C5.
I also bought a half dozen 7A5, for no particular reason other than it looked like an interesting low voltage tube.
Win W5JAG
Win W5JAG
So many of those tubes are triode pentode combos made for tvs and all have similar ratings. Why would companies make that many numbers with the same ratings?
"Why would companies make that many numbers with the same ratings?"
From looking thru the GE handbook, it looks to me like the tube sections are just plucked out of more common twin triodes or single pentodes. They probably just put whatever the TV guys wanted into a bottle for space efficiency. Some are just different pinouts of the same combo too. (6BN11 6V11)
Don
Don
Well I ended up buying 6 955. At a buck 70 I couldn't pass it up.
If the sale is still going next weekend I will have to pick up a few 3c24 because 10 bucks a pop is a steal.
Nick
Nick
nhuwar said:Well I ended up buying 6 955.
Wonderful little tube, my 6CW5 SE uses the 7-pin equiv (9002) for the front end. I'ld buy more 955s if it weren't for the couple dozen already in the parts bin.
I'm going to use mine for my line stage.
Just didn't want another 6sn7 or the likes. I like things a little different.
Nick
- Tubes / Valves
- Tube sale at AES
