Power supply for Amp 48v
hi there,
this is a common enough transformer, it maby that the specifications of this part that they give is misleading.
here is my interpretation of the spec
Primary to suit your local mains supply (they specify 220V) check this.
secondary 48 or 50Volts, 75 to 150 VA (i would use 150VA)
the secondary can be 2 windings of 24 or 50 Volts joined together in series.
Hope this helps
