Help a noob build Pedja Rogic's J-fet buffer
I have one of the original briangt gainclone kits. just got it working and while it sounds good, it is a bit rolled off and weak, dynamically. Same as I have encountered with any amp with a passive attenuator.
so in my searching, I came across Pedja Rogic's J-fet buffer. I want to build one into Peter Daniel's integrated amp case.
questions I had were,
1. Where do place this buffer in the signal path? I assume before the volume pot?
2. Can I use the 25k pot I have now, or do I need a different value?
3. The schematic calls for a 15+15v psu. Can I just add windings to my current 100va toroid?
4. Lastly, will the j-fet be susceptible to hum from the toroid? Will it need to be shielded?
Thanks in advance.
