hi does anyone know the secondary voltages for a nad c320 amp not the bee one im having a hard time finding any service information for this!
thanks
chris
thanks
chris
NAD C320 service manual
Idle rails are +46V/-46V, then power transformer is about a 60V-CT/2×30V (loaded) one.
Hi, I've got the same problem, seems like the toroidal transformer primary opened... it's strange, when checking it one of the wire connecting from the secondary to the board was cold soldered! Anyway, thanks for the info on the voltage, I had contacted Toroid international to buy a replacement but they said that was NAD proprietary and would not sell straigth to me, went to NAD website and contacted the representative in malaysia... but no response, so I was thinking about unwinding it to see if there's a fuse (you know what i mean, at times in transformers there are this in line fuses among the first windings) So before i started checking that out i wanted to see with you guys if you know if there's a fuse enbedded in the transformer. Any info is welcome, and if more details on the output voltages perhaps i can get a replacement done.
