I read over the PE Xover for n00b link, and laid out Zaph's Xover with pictures. Am I doing this right? Are the inductors too close together?
Thanks, Brendan
Thanks, Brendan
You might notice that all of the worst cases involve having coils that run parallel to each other. Even though the inductor axes may be at 90 degrees, if any of the wires are parallel there still will be coupling.
You seem to be doing all of your homework for this build, I hope you are documenting the build (at least pictures) and that you will post a thread on your progress!
Good luck with the build,
David
David
hello, could you giveme an opinion on my crossover layout?http://img245.imageshack.us/img245/1393/im000072vl6.jpg
The two tab are 20cmx9,5cm and will be placed as shown in the pic.
thank you
thank you
gtforme00 said:You might notice that all of the worst cases involve having coils that run parallel to each other. Even though the inductor axes may be at 90 degrees, if any of the wires are parallel there still will be coupling.
David
Thanks, so it looks ok? BTW I'll post a thread once everything gets here
Brendan
Peter N,
Your inductor placement is good.
Brendan,
I'm a bit confused by your schematic. I do not see the series 0.1mH inductor on Zaph's schematic. Where did it come from? As far as the placement of the inductors go. I would try to separate the woofer and tweeter parts of the crossover (perhaps put the woofer crossover on the floor of the enclosure and tweeter crossover on the ceiling of the enclosure?) This would allow you to separate the inductors further to minimize crosstalk. As drawn, assuming the 0.1mH inductor is correctly included, I would be concerned about mutual coupling between the 0.28mH and the 0.1mH as they have parallel coil segments that are close together.
Regards,
David
EDIT: I should rephrase the "parallel coils" part of my previous comments. It is not enough to just make sure that the full coil diameters are not parallel. If segments of the coils are parallel (as with the inductors in your drawing) there will be coupling. The best case is where the inductors have no parallel segments as shown here:
Brendan,
Regards,
David
I see now, it is an updated crossover for a replacement tweeter. I would put more distance between your inductors and try to make sure they cross at right angles to each other. Beware of the common error of laying an inductor flat and standing another inductor up next to it as shown in your drawing above. The fields will couple and you will have crosstalk between your tweeter and woofer circuit. If you have to keep the inductors closely spaced to fit in the enclosure, elevate the large inductor so that its central axis is lined up with the inductor that is standing up.
hello, I found a site wich explain well, also with graphics and FR how to place coils, unfortunatly is in italian
http://www.audiofanatic.it/Articoli/Bobine/Induttanze.html
http://209.85.135.104/translate_c?h...diofanatic.it/Articoli/Bobine/Induttanze.html
look here:
http://209.85.135.104/translate_c?h...ofanatic.it/Articoli/Bobine/Induttanze15.html
look here:
We saw that mount inductors located orthogonal minimizes interference but ... Yes, but there is one! To obtain the maximum inversion is necessary to comply with the maximum relative squareness with a perfect centering axis relative. One deviation to one of the lobes of emission offsets for almost the entire effort, bringing the signal captured almost at the highest level.For this reason it is better to mount inductors axially with respect to crossover, so that the axes lying on the same floor
I tweaked the layout yet some more...how about this? Any glaring problems?
Brendan
Brendan
Need some advice ASAP please!
Brendan
Brendan
Correct!cyberspyder said:I really need to know guys....anyone? (forgive me if I appear impatient, but this is the only day I can work on them)
crazyhub said:Correct!
I gave you my opinion on your coils placement because of your last post "I really need to know guys....anyone? (forgive me if I appear impatient, but this is the only day I can work on them) "cyberspyder said:Correct what? Nvm, I got it done. Emailed Troels and he explained everything to me.
- Inductor Placement on Xover
