I was making some tests because a ground loop with computer as source.
I was testing different power cables on the Aleph with different multi outlet plug strip, all used and without problems, but with different characteristics.
A typical test: power on, 10 seconds of music, power off, change the cable or the outlet, power on...etc.
I made it about 5, 6 times. Last time that I powered on I heard a kind of "snap", burn smell for few seconds and the Aleph since that moment is mute.
Panic!
I watched the fuse on the input, but is good.
Please, somebody have suggestions?
Thanks in advance
rob
Panic!
Thanks in advance
rob
...well, Aleph 5 have 2 separate channels and the common power input. Well being it mute in both channels I think that the problem could be in the power input, I don't think is in the 2 different channels, or at least is more difficult that something burned in both channels.
