Two companies come to mind right away.
www.madisound.com & www.partsexpress.com
Both companies offer complete kits with cabinets.
You might also search this forum for other companies.
Larry
Larry
You could find a design you like then contact Scott Stein to build the cabinets for you.
http://www.steinaudio.com/
Partsexpress just came out with some redesigned bookshelf sized enclosures, and I'm assuming they'll do the same with the rest. However, they only go up to 1 cubic foot volume, which obviously isn't floor standing/fullrange. And of course, you'd still have to cut the blank baffles..
http://www.partsexpress.com/webpage.cfm?webpage_id=3&CAT_ID=48&ObjectGroup_ID=603
Madisound offers the MD38T floorstanding cabinet (9 x 38 x 11, 38 liters) and it has an internal shelf that can be moved around. Still not huge by any means, and you'll be limited to 6.5"/7" woofers. Maybe you could fit some 8's in there, but I doubt it. Regardless, it'll definitely play a role in determining your woofers, as you've only got up to 29 liters to play with...or maybe 38 if using a sealed back mid/tweet..
http://www.madisound.com/about/cabinets.php
http://www.madisound.com/catalog/index.php?cPath=178_155_395
I think Zalytron in NY will build some really nice custom cabinets for you, but only for drivers that they sell..
http://www.zalytron.com/boxes.html
GR Research offers his kits with some pretty nice cabinets..
http://www.gr-research.com/
I can't remember whether or not Raw Acoustics has any enclosures for their kits, haven't been there in a while...but I do know they have pre-cut baffles..
http://www.rawacoustics.com/
You might could try contacting Kyle Richardson at Acoustic Visions and see if he could build your enclosures for you. I gotta warn you though, it's not extremely cheap, and anything more than 2-channel can get pretty expensive..
http://www.acoustic-visions.com/
Timn8ter said:You could find a design you like then contact Scott Stein to build the cabinets for you.
Even better! While this thread is up, anyone else that offers custom cabinets for any drivers/design?
BHTX said:Even better! While this thread is up, anyone else that offers custom cabinets for any drivers/design?
We do... but you are on the wrong side of the continent for anything that isn't small, We do offer flat-paks for the Frugel-Horn and soon for the Fonken.
dave
I do, but there are limits on size that I can ship. And I'm slow. Located in Baltimore, MD.
http://www.diyspeakercabinets.com/
BHTX said:Partsexpress just came out with some redesigned bookshelf sized enclosures, and I'm assuming they'll do the same with the rest. However, they only go up to 1 cubic foot volume, which obviously isn't floor standing/fullrange. And of course, you'd still have to cut the blank baffles..
If they came out with a floor-standing curvy cabinet that was 40" tall, had a baffle that could fit the RS225, and was at least 2 cu ft, my wallet would be in trouble.
Dan
- kits with cabinets?
