UGS Power : it's U.P.
Hi all,
Being personally fond of the sound of my UGS modules - nobody's perfect -, I wanted to test some ideas we've been talking about with my friend Philbyx, who owns the paternity of the idea ;) His sharp neuronal connections made a link between the UGS schematic and the Zenquito, a french PP amp which seems to be quite highly appreciated from French DIYers (http://perso.orange.fr/jm.plantefeve/sche.html). So we decided to take this concept further and, stimulated by the Aleph-X brainstorming, we began to test and build something.
A word of warning here : this beast uses the now infamous dual japanese JFets 2SK389/2SJ109. Shame on me, I know... But I had some of them... What else could I do ?
So here's what I finally came upon (see attached pdf)... Nothing very fancy or new, just basic building blocks put together. The front end is a basic current-mirror ugs, with increased current output capabilities to properly drive paralleled mosfets. The current mirror transistors have been changed to handle the power requirements, and I used 2SC2911/2SA1209 for their nice characteristics.
The front end is followed by a classical Vbe multiplier for biasing a typical triple pushpull of mosfets. I'd rather see this biasing stage as a kind of shunt regulator, but that's only a matter of words :) I kept the resistor network at the output of the UGS to be able to test the difference between global and local feedback (using jumpers).
The power supply is built from a 2x18V 400VA transformer (1 per channel) with a CLC filter, giving a rough 23V at rails. The front end is powered a bit higher (30V) using a voltage doubler (à la A75 ;) ), followed by discrete regulators, to provide more output swing from the front end.
The mosfets are idling at 250/300mA each for the moment, and on the bench, the max output power (before clipping) is close to 100W in 8 Ohms. More than I need ;)
I've added an on board DC protection, but I must confess I'm amazed by the offset performances : under the mV on diff offset, and under 5mV on absolute offset... :cool:
It's only at prototype stage for the moment, and I began the listening sessions comparing them to my Aleph X.
How to say... In a few words, the AX is rounder, warmer, softer... The U.P. is sharper, wider, faster. The AX gives a "classical" class A feeling, with warmth and lushness, but a bit of fuzzyness. The U.P. seems a bit "cold" in comparison, but seems to be more "balanced", in the sense that it does not seem to emphasis anything. It goes higher (some veil on the AX in comparison), is faster. The bass has a better slam than the AX which seems a bit slow here. And most of all, the U.P. is awesome on the spatialization. Not that it widens everything outrageously, but it's much more accurate and refined, much less fuzzy than the AX. Every frequency seem to be much more isolated and located...
Well, I'm not good at putting it in words, but both AX and U.P. are marvelous amps, and I will have hard times to chose. I still have some test to do on the feedback path (still haven't done extensive listening on the local feedback configuration).
Some photographs of the beasts at work :
The AX/U.P. challenge
One channel :
Closeup :
Once again, a zillion thanks to Nelson Pass for guiding us to the stratosphere :cool:
And warm thanks to Philbyx ;) Feel free to post your version here :)
Thanks also to Marc and Ninio, for supporting this without listening :D You'll be rewarded :)
  • up.pdf
just two questions:
what type of copper board did you use?
I usually use bungards 35u presensibilited.
Good job with the routing of this amp.
Just wondering why the copper looks silver shiny instead of copper.
Did you coat your board with something?
Last question:
Very interesting your review of the two amps (UGS and AX); since you did a great job with this, would it be possible to see some pics of your aleph AX inside and outside?
Stefanoo said:
just two questions:
These boards were only for testing purposes, so they're suboptimal : 35µm copper, power traces a bit too narrow, etc... The copper has been tinned using a tinning solution for pcbs.
Last question:
It has been presented here : http://www.diyaudio.com/forums/showthread.php?s=&threadid=24316
Interesting: great job with your AX.
The PCB looks sweet.
were both PCB, AX and this, used only for testing purposes?
Where do you get your board done once they've passed testing session?
What specs do you use for the board: thikness of the copper and so on?
I'm approaching to my aleph P 1.7 tonight i will make the board...and next....who knows when....the time .... this is the deal.....but anyways....my next would be AX.
I just went a bit slower than i could 'cause i had problem to self make a double layer boar.
I might.....and outline might... found a way to line up the two layers...hopefully tomorrow i'll be able to post something.... and so...if this works....my aleph AX should go a little faster...in terms o developing time :) ...at least in reguards of the board and stuff...
AX pcb remained the same. It has somewhat wider traces, but most of all shorter. So trace dissipation was not a concern here.
If the U.P. boards are to be remade, they will be made by a professional shop, but in an indefinite future.
I'd have to widen the power traces and have them with a 70µm thick copper
Hi Cheff,
Beautiful job on the amp. An excellent project - and thank you for sharing it. That definitely looks like a contender for the ".5" title in my opinion!
By the way, that's a very interesting update on the relative offset adjustment from the one shown in the "adventures" thread.
Graeme
Thanks Graeme,
Yes, the offset stability remains quite awesome. I planned some place on the pcb for the 'Aleph-X style' power resistances from output to ground, but the first tests showed they were absolutely not necessary ;) Even with the feedback loop not including the output mosfets, the differential offset is below 5mV. Absolute offset is wandering a bit more than with global feedback, but stays within +/- 10mV. And no matching other than the power mosfets has been done.
jacco vermeulen said:
Jefe,
the ones in the picture are produits artisanale de la maison ?
(Escoffier would have been proud, i see you even fixed the mice problem.)
Jacquot,
(Un)fortunately, c'est un produit semi-artisanal :)
Pcbs are made by a local shop, but à l'ancienne : insolation, etching & tinning are made à la main.
And for the mice, i've got a cat to take care of them. Les souris d'agneau, je m'en charge :)
Nelson Pass said:
Beautiful work.
:cool:
Deep thanks, Mr Pass.
Really.
