Ok, I have already posted on building a gainclone . However, cleaning up some stuff in the attic I came across a Garrard recordplayer I still had lying around. The player itself is a SP20, which is not really nice, or so I have been told. However, it does also house a tube amp. The question then is, is that usable at all?
- Can I pull it out (that means smashing the casing as most of the wood is glued together) and use it to amplify something else?
- How do I make it suitable to amplify a CD player?
- Is this something a beginner can do? -with a bit of forum help...
- Or would I just be better off selling the Garrard for peanuts and buy a chip from the money?
Update:
Through the TNT-Audio list Peter Boser replied to tell me he found out more on my Garrard. You can find it here: http://www.grammofoon.com/frameset....om/Garrard/garrard_sp20derby.htm&ContentFrame[/url]
After careful consideration (and a great tip from Peter), I did decide I wanted to test it and hooked up my laptop to the Garrard. 1967 meets 2007. Forty years separate these machines, but with a din to 3.5mm jack they could talk together. And boy, did they do that. I had to talk a friend of mine into bringing me an old speaker I left at her place ages ago, because that had the old DIN loudpeaker plug needed for the Garrard. Luckily she brought some spare ones as well, so I could hook up an old set of JBL's I have sitting around. Now, I have a smile on my face the size of an old vinyl record. (No, i did not trust the needle on the SP20, so I did not try an record on it.)
First impressions:
- The adjusters for volume, balance, treble and bass are worn. They creak and sometimes if you tap them, they work better. There is room for improvement there.
- The sound was pretty nice and after warming up a bit, it worked with the JBL's with ease.
- There is a lot of work to be done
What is up next? Well, let's get it out of the box it has been in since 1967.
- It will need new adjusters and some of the old ones will need to go.
- It will need to get new speaker terminals
- New input terminals
- A new euro spec connector for the mains
- A new mains cable
- And I will need to find it a new case
Funny, someone just made me an offer of 40 euro's... I think I am going to pass on that...
The Garrard Derby Stereo as it has been since 1967...
First impressions:
- A new mains cable
