I've seen various website modding their gear where they parallel 0.1uF metallized polypro with the electrolytic cap.
I understand that this is called bypassing.
But when I searched the net, it seems bypassing is commonly done on the supply pins of the chip (opamps for example).
Is there any value to paralleling film caps to electrolytic caps? If yes, is film caps the best type to use?
Thank you very much
ps. I'm not sure if this fits with power supply design but in most instances, the power supply caps are the ones that are bypassed.
Thank you very much
Those high speed bypasses are normally to be used at the point of load, that is at the chip or output transistors. If you bypass the 'lytics in the PSU the way to the point of load still has wiring inductance which degrades the effect of the bypasses. That inductance is also the reason why bypassing both the supplies and the point-of-load is a no-go, this forms a C-L-C circuit that can easily ring at RF frequencies. If bypassing is used at the PSU to filter incoming RF noise, there should be some resistance on the way to the load (ferrite bead, e.g.) is needed when the load is also bypassed. Any good film capacitor will do, ceramic capacitors will also be ok. The return point (GND connection) is critical, when the GND gets disturbed by high/fast current pulses from the bypasses not much is to be gained. One will have to measure things (a lot of things) to make sure that bypassing actually impoves perfomance, there a quite a few gotchas...
Regards, Klaus
Regards, Klaus
the issue is that there is significant ESR and ESL in the larger caps, they make poor caps at higher frequencies. So some designs call for the addition of film caps, which act like caps to a higher frequency.
in industry, ceramic caps are used for the smaller size. because the ceramic caps are not in the signal path, there is less concern about possible issues.
no,jarthel said:I have read that bypass caps should/must have higher voltage that the electrolytic. true?
each cap must be rated to exceed the highest operational voltage.
theChris said:the issue is that there is significant ESR and ESL in the larger caps, they make poor caps at higher frequencies. So some designs call for the addition of film caps, which act like caps to a higher frequency.
This is a myth. Larger caps exhibit lower ESR and overal lower impedance. Also, electrolytic capacitors are much less inductive that things such as the PCB traces connecting them (unless power planes are employed).
Furthermore, parallel capacitors usually resonate with parasitistic inductances leading to increased impedance.
There are only a few situations in which paralleling capacitors is actually advantageous.
The concept is simple, but the reality is anything but. Yes, electrolytics are far better than their reputation, but at some tens of kilohertz, they can become more inductive than capacitive. I have some nice manual capacitance and inductance bridges, but at work we have a fancy HP LCR meter that covers 20hz to 2Mhz, a difficult range for most of the equipment a hobbiest can get his or her hands on. It's also fast, so I ran measurements on a bunch of different caps and put the results in an Excel spreadsheet. If I did the math right, you'll see ESR in ohms vs frequency for each cap. Note the log scale. If you were going to parallel caps, you'd need to convert the series model to a parallel model, but it's still interesting to see the differences in ESR between say, a big tubular polypropylene, a dipped tantalum, and a low value mil spec that's either polypropylene or teflon- not sure which.
Excel Capacitor Comparison (.xls file)
If you look at the 47Lab Gaincard, there are no bypass caps. At $3000, you would think if it really would matter, they would have added a bypass cap....
I agree, most time, bypassing large caps with smaller caps at 1/100 the bigger cap is a myth.
If you can hear the difference with the bypass and it is better, then go for it. Otherwise leave 'em out...
At $3000, one would also expect to get a decent amplifier... the Gaincard doesn't seem to be one (I'd say it rather is a money making machine)...
http://stereophile.com/solidpoweramps/120147/index4.html
I guess that bypassing would not have improved it's performance too much, as it is limited by other design factors.
Regards, Klaus
Regards, Klaus
I didn't realise that 47 Lab's gain card was that bad.
They only ask for 24W into 8ohms and it can't even manage that easy bit of the spec.
Then the output falls 2.0dbV into 4r0. Terrible.
Talk about brass neck and profit margin.
Now I would never pay $3000 for an original Gaincard, but if you look at all those clones, they all have bypasses, snubbers etc added to the original design. No more 9 components.
I have alway heard that Gainclones (at 1/50 the cost) don't sound as good as the original Gaincard, but could it be that it is those that acually own the Original are the poor blokes that are saying this???
I like Gain Clones. For $60 in parts, they sound great. I just don't expect or claim it to be one of the best sounding amps on the planet, like the Gaincard.
Some claim that the power supply is a part of the signal path and therefore one would believe that caps in the power supply should be as "audiophile" as possible.
In my SiriuS power amp (now marketed under the name of GamuT) the power supply elcaps are bypassed by film caps.
I understand that copper foil paper in oil signal capacitors sound better as signal coupling caps than any type of film cap. Does this predict that copper foil paper in oil signal capacitors would be good for bypassing power supply elcaps?
To demonstrate that high inductance in modern electrolytic capacitos is a plain myth, check the following datasheet:
http://www.epcos.com/inf/20/30/db/aec_07/B43501.pdf
Self inductance is rated at approx 20nH (0.125 ohms reactance at 1Mhz) for those medium sized high voltage electrolytics. Big film capacitors exhibit similar inductance values. Electrolytics should be considered good up to 1Mhz.
Contrary to popular wisdom, the main purpose of local bypass near high speed ICs is to compensate for PCB inductance (at frequencies considerably higher than 1Mhz). Remember that wire self inductance figures are in the 5nH per cm range (so one of those medium sized electrolytics is not more inducive than two inches of plain wire or PCB track).
"....the Gaincard doesn't seem to be one (I'd say it rather is a money making machine)....."
Yes.....business ia a money making machine !
This fact has bugged me for a long time. I've been on both sides of the business. Manufacturing and buying.
I've also been lectured ( in a university ) a lot on this by professionals from Switzerland.
My conclusion is that one cannot complain about costing . You aren't being forced to buy anything and it isn't essential for living comfortably. The maker might have spent a lot of man hours perfecting 'their implementation' and might want to get back their 'man hours money' over a 'limited sales' that they project.
If you like what they make then you might need to cough up for their product. If not , there are several other products to choose from.
You will never get to know how much they spent on developing their product and so it's very hard for outsiders to determine what the product really should cost . It can never be just the cost of parts. In fact that is just a fraction of the overall cost.
That's what DIY is all about . You spend a pittance ( not always !)on parts and don't have to plonk down on your time ( far more expensive ) and help ( others time and hence money ) that is not visible at all. But it does make us happy and think we got it done cheap !
So maybe we needn't clobber the makers for thier prices . Just clone them and be happy ! You don't have to buy it of course.
Cheers.
Cheers.
Eva, I've been measuring various caps on a $16K Agilent LCR meter that is accurate to 2Mhz. Though I believe electrolytics have gotten a bad rap, they aren't that good either. Smallish low ESR electrolytics that I'd expect to be quite good are still all done in terms of capacitance and ESR well below 100khz. Even a similar value OS-CON is in trouble at 200khz. Larger caps will lose effectiveness at surprisingly low frequencies like 5 or 10khz. Yes, they still display reasonably low impedance and will shunt high frequencies to ground, but their ability to store and return energy is greatly diminished. IOW, they act as a low value resistor with a phase angle closer to -45 or even 0, than to -90 degrees. I don't believe in bypassing filter caps at the cap- this is far better done at the circuit where the cap can do some good, or at the bridge, where the RF can be shunted, but the electrolytic can't do the job alone. FWIW, though I've been measuring caps for decades, I've changed my thinking on this matter greatly since having access to a meter that can do both high frequencies and low impedances at the same time. Traditional bridges, though I love 'em, aren't up to the task.
edit/addition- Notice how in that cap data sheet they concentrate on impedance and ESR, but make no mention of effective capacitance at high frequencies- nobody does.
I ran some equations here:
http://www.diyaudio.com/forums/showthread.php?postid=1229783#post1229783
which show that bypassing isn't a matter of spraying random smaller capacitors on top of big ones. You do want to know the parasitic values for the large cap, and low-ESR capacitors paradoxically can get you in trouble if you bypass them with too small a film cap.
The math gets a bit involved, but the end result is simple: find the equivalent series inductance (ESL) and equivalent series resistance (ESR) of the large capacitor and apply the equation
Cb = ESL/(ESR*ESR)
to find the optimum value of Cb, the bypass capacitor.
Some folks avoid the whole mess by running a few smaller electrolytics in parallel instead of a single large one, which increases capacitance while also decreasing ESR and ESL. It's a neat trick if you have the room.
Cb = ESL/(ESR*ESR)
Conrad Hoffman said:Eva, I've been measuring various caps on a $16K Agilent LCR meter that is accurate to 2Mhz. Though I believe electrolytics have gotten a bad rap, they aren't that good either. Smallish low ESR electrolytics that I'd expect to be quite good are still all done in terms of capacitance and ESR well below 100khz. Even a similar value OS-CON is in trouble at 200khz. Larger caps will lose effectiveness at surprisingly low frequencies like 5 or 10khz. Yes, they still display reasonably low impedance and will shunt high frequencies to ground, but their ability to store and return energy is greatly diminished. IOW, they act as a low value resistor with a phase angle closer to -45 or even 0, than to -90 degrees.
We are more or less telling the same story. People must understand that electrolytic capacitors are *not* inductive, which would result in phase shift becoming +90º (positive) at very low frequencies rather than remaining at -45º or close to 0º as you mention, and in impedance rising at 6dB/oct. However, as frequency increases, capacitive reactance becomes negligible and ESR dominates progressively resulting in a phase shift that sweeps to 0º and an impedance that tends to become flat. Thus electrolytic capacitors behave as very low value resistors at least up to a few Mhz, *not* as inductors.
Agreed- I think the idea may come from the fact that most capacitors are wound, but the geometry is not such as to form an inductor. More important is keeping the leads short.
I don't have the answer, but wonder what it would take in terms of caps and their type, to create a high value (100uF or so) composite cap that would maintain all it's parameters to 100khz or so? That means it would show close to full capacitance value and close to -90 degrees over the full range. I did a brief paper exercise with some known caps, and it's harder than one might think!
...simply measuring.. that's it. Much better than guessing!
Conrad,
I would be quite happy to get your paper exercise!
Conrad,
- Power Supplies
- paralleling film caps with electrolytic caps
