New Sonic Impact T Amp board
I just got another T Amp and its circuit board has been redesigned. The layout is different. Fortunately, it's now even easier to replace the input caps.
Here's how to do it (I'm assuming the unit is powered down).
1. Turn the volume control all the way up.
2. Run an ohm meter from each channels' input to the coupling caps to find them. They are two small monolythic caps right on the back edge of the circuit board on its top (the board is turned upside down in the unit). You'll know you've got the right cap(s) when you see 0 ohms on your ohm meter on one side of each cap.
3. Remove these caps and solder two 4 inch wires to their connecting terminals. Run these wires on top, as the hole where the wires hang down is occupied by the volume control when the cabinet is put together. I used Cat 5 stranded wire, but wire wrap wire (available at Radio Shack) will also work. This wire has to be THIN (26 guage or smaller).
4. Make up a composite cap by putting two of these caps in parallel (per channel of course):
http://www.radioshack.com/product/i...Metal+Film+Capacitors&fbc=1&parentPage=family
http://www.radioshack.com/product/i...ectrolytic+Capacitors&fbc=1&parentPage=family
Solder the wires from the old caps to these, and mount these caps to the back of the battery compartments with some tape or glue.
The result will blow you away at how good it sounds. And, even better, it's CHEAP! You can do this mod. for around five bucks.
