Need pro advice!
Hi! Created my first amp! Sounds good at +-25V, but i will increase it to +-60V! I have some noise like "raining" in midrange! May be must change some transistors or capacitators or resistors ... I am newbie in electronics. I created center gound, a rectangle in center of PCB. Transistors are cold even at full load (+-25V 8ohms ). Everything seems to be fine just this noise!!! Please help!
Thanks a lot!
I would say running this circuit as is from 60V is asking to destroy the small transistors due to exceeding Vceo and maximum dissipation!
IMO, do the following:
* Replace R4 with a proper current source
* Use a cascode in the first stage to decrease dissipation in Q1, Q2. Try with a 30V zener as the reference.
* Use another transistor instead of D5, forming a current mirror
* Use MJE340/350 instead of BC327/337
If you want to use more MOSFETS, add a driver stage.
R1 should really be equal to R7 to avoid offset issues.
If it's oscillating, try compensation capacitors around Q3 and Q4, from base to collector. Start with 47pF.
edit: take a look at Bora's Sigma amplifier
