peerless 830515 home use - ideas
I have a 12" car sub.
It is the peerless 830515, xls series.
you can see some specifications in here
I' m thinking to make an enclosure for home use.
I 'm a bit experienced making enclosure for cars.
I 'd like from you some ideas to make this home enclosure and to choose the suitable amplifier.
PS. I' m really sorry for my bad english, I hope that you understand me. Thank you in advance
I played with the specs in Unibox, Seems this is a good sub for music, perhaps won't go low enough for most HT fans without a large box, seems to need about 60 litres tuned to ~30Hz to get flat down to 30Hz, probably need a fairly steep LP filter to deal with all those peaks too..
